Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
My phillip 51 inch will not turn
Hi guys my name is carlos i have problems wiht MY 51 Phillip it will not turn on.when i press the power button nothing happens it just makes like it will turn on then the power button blinks of and on and thats all it does it will not turn. thanks i need all the help i can get on this issue.
I just got the tv for free for same problem blinks 9 times over and over if you pull the power cord for 1 to 4 days it works but cant shut it off looking for answer not just the power button on tv
Posted on Jun 20, 2008
    Problem Solver:
  • 7 Answers
This happened to me once i think the problem is that the button is used so infrequently that it sticks try pushing it very hard as many times as needed and id and when it comes back on dont use the button anymore just stick to the remote
Posted on Apr 21, 2008
Phillips t v 51
use diagonal cutting plier grab the head of screw and work it out
Jan 29, 2014 | Suzuki Cars & Trucks
I have a Magnum air compresor 4.5 hp the unit will come up to 120 psi shut off then leak the tank to 0 psi how do I remove cover on this unit to check release value also does the same when unit is turned...
Hi, my name is John. Welcome to GixYa. Check all the air lines, check the line coming from the pump to the tank. You may have to remove it to inspect it. Use a Phillip head or it might be a quarter inch socket with extension. Thanks for choosing FixYa...John
Nov 19, 2010 | Magnum Air Tools & Compressors
Cannot find code for dish network remote to control emerson 32 in
Phillip with DISH Network here. We would be happy to help with that.
Step 1:
Press and hold the TV Mode button until all mode button back lights come on, then release.
Step 2:
Use the number buttons to enter the device code corresponding to the equipment. In your case we are going to use the Emerson codes: 764, 632, 648, 670, 699, 194, 537, 537. Then press the pound (#) button.
You should be able to control the volume and turn the TV on and off, if not try another code. Although we try to facilitate you in controlling both devices with one remote we cannot guarantee that we have codes for all the different brands and models of TV's.
Phillip Chang
DISH Network Customer Service Representative
Dec 12, 2009 | DISH Network IR Remote Control
My supertooth light is not detected by the phone
Hi
You must switch the unit to detection mode,so that it is detectable(visible) to your phone.
On a Nokia bluetooth headset the power button must be pushed untill the light turns to solid on(not flashing)
Check the owners manual if have one.
Regards
Phillip
Oct 16, 2009 | Blueant Supertooth Light Bluetooth...
Picture problem
This is a common problem with this TV set. You can get the parts, chips, and instructions to fix it your self from www.TvRepairKits.com
Aug 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Fix my line problem but red LED flashes five times
Hi Guys, Looks like your advise took care of the problem. I adjusted the power knobs for each of the RGB guns on my Sony 51 inch projection TV. The color looks great and I don't seem to have the blinking indicator light bugging me any more. I will be sure to suggest you folks to anyone with these type of technical questions.
GREAT JOB!!
Jan 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Phillip was 32 inch flat screen
maybe you can buy another remote control which is the universal remote control.
May 04, 2008 | Gateway FPD2275W LCD Monitor
Phillip tv
Probably bad inverter board. It has a short in inverter board and as soon as it powers up it detects the excessive current draw and shuts the set back off. Open it up, unplug the power supply connections to the inverter board then try to turn it on, if you get a green light then the inverter is bad. Try E-bay for replacement board.
Apr 16, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Phillips 51 will not turn on
Unplug from wall outlet and wait for at least 5 minutes. Capacitor needs to discharge and then plug unit in. It should work then. I paid $100 to learn this from the tech.
Feb 14, 2008 | Philips 51PW9303 51" Rear Projection...
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
