Question about Epson Stylus R265 InkJet Photo Printer
Monochrome Printing All genuine materials used cannot print pure black even though all settings say grayscale it looks tinted, (more ink) greenish, (less ink) pinkish, depending on amount of ink in certain areas. Is black a mix of all colours or is the black bad on this printer?
  • mikepringle May 25, 2008
    Cannot print black and white photographs without red or green tints to them tried changing just about all the settings but got through a ton of paper (and time) trying to find a solution - extremely frustrating - any ideas?
Monochrome Printing - 180px-color-subtractive-mixing-cropped.pngHeres your answer
Posted on Mar 06, 2008
  • AJ1974 Mar 06, 2008
    Just looked it up on Wikipedia. CMYK. (Cyan, Magenta, Yellow and Key Black). When CMY mixed they create black. Could be dodgy ink. I'm no expert on that i'm afraid
    AJ
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
Both lights on printer flashing
If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
Aug 20, 2008 | Canon PIXMA iP1600 Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
I cannot print in color even though I can print
What has changed?
Is it possible that the color cartridge is empty?
Check the driver properties and make sure that the driver hasn't been changed to "Monochrome", "Grayscale" or Black and White.
Don
Jul 02, 2009 | OKI C3200n Led Printer
Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Canon MP830 - extreme ink useage
According to a service manual for a similar Canon printer, the grayscale printing should only use the Pigment Black ink PGI-5BK.
On fast it is 300x300dpi with 1 pass, standard is 600x600dpi with 1 pass and high is 600x600 with 4 passes.
On plain paper in colour it is meant to still only use the C/M/Y and again the big pigment black ink PGI-5BK, it only uses the smaller black ink once you set it to use a photo type paper in the printing settings.
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson Stylus R265 InkJet Photo Printer Logo
115 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
