Mitsubishi VS-70709 TV Logo
Posted on Jan 23, 2010
HOW CAN I GET RF FILES OR INFRARATED CODES FOR MITSUBISHI TV VS 70709
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 18, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
535
Points
Reset passcode for vs60609 Mitsubishi tv
check the english service manual
http://www.manualsdir.com/manuals/118985/mitsubishi-electronics-vs-60609-vs-70709-vs-60719-vs-45609-vs-55609-vs-50609.html?hl=ru
Tv turns on for 20 secondsthen shuts off
There is short circuited component/s at its circuit board. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Screen was ok and suddenly make a noise as a short circuit and te screen went out
oops-This is dangerous for peple not trained in service 1-Possibly high voltage makes arc to ground.2-check horizontal output for bad contacts.
What fuses go to model vs70709 television 70 in and where can I purchase them
hello
There may be any reson for the fuse to blow up. Some kind of short circuit may exist in your TVs mainboard, or power supply regulator section. Usually colour TVs uses 3.5amps fuse in series with mains supply. If it blows off again and again; you should contact a technical expert to retify the problem. Never put no more fuse in it as experiment. It may make your TV irrepairable.
1helpful
I NEED TO MOVE MY MITSUBISH VS 70709 UPSTAIRS AND I NEED TO KNOW HOW TO TAKE THE BASE OFF FROM THE SCREEN
This may be one of the models that comes apart--if it is on either side you will see two plastic caps--beneath are either regular bolts or L shaped ones you turn.
Most of the sets that had the feature needed the front screen removed first to do this.
If you do not see the black plastic caps (two on either side) it does not have that feature.
SD TECH
Something buning back of tv red lines going off
Ur tv have convergence problems,it dead.Ur 2 STK convergence ICS are defective,and all or some of it supporting resistors.The shop will cost u $300-350 for parts and labors.
2helpful
My VS-70709 willclick when the power button is pushed, but will imeditaly turn right back off. Any ideas?
HI, you have a weak ballast. this is the power regulator for the lamp in your set. replacing the ballast will fix this issue.
I have a VS 70709 not getting any picture
Code 2_3 is Horizontal Deflection Problem
Tv is dim
Ned more info as do all things including the on screen display look darker then normal???how old is set??
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
