Question about Indesit W 123 Front Load Washer
Indesit wd 12 drum
Why is my indesit wd12 drum making noise when at spin and durm itself is short circuit ?
  • 67 Answers
Please rephrase your question as what you are explaining does'nt make sense
Posted on Feb 14, 2008
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit WD12 door will not open once cycle has finsihed
I have the same problem and am now hoping you already have the solution ?!
Oct 09, 2009 | Washing Machines
Indesit WD12 washer dryer with a leaking door seal
this is no easy job and you will need a copy of the work-shop manual; sometimes they can be downloaded of the internet. There are no real specialist tools, but im telling you now there will be a lot of very red knuckles .good luck.adrian
Feb 22, 2009 | Indesit W 123 Front Load Washer
Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Jan 26, 2009 | Kenmore 43052 Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
WD12 Indesit washer/dryer
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: Timer- If your washing machine fills with water and begins agitating, but the timer won't advance. Then you need to replace the timer. Water supply problem- If water doesn't enter the machine when you start the process- check water entrance pipe, myaybe it was bend (if you have there a tap - see it is open). Check that water entrance valve works (it is an electromagnet valve,loocated at the pipe's enterance to the machine). If it doesn't work, test that it get power. In case it doesn't get power, it seems that the problem is with the timer unit. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve.
Mar 22, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
303 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
