Washing machine making banging noise
I have a front loading machine. The banging noise sounds like something metal, loose, moving around. I think it could be even perhaps a coin. The object i think is trapped between the inner drum, and the outer drum. Is there a way i could easily get between the drums to get the object out, or would you recommend it would be a better idea to phone an engineer.
    Problem Solver:
  • 15 Answers
Dear Allahba,
First question you want to ask yourself is "how mechanical am I ?) If you feel comfortable pulling the thing appart and confident you can get it back together then go for it. You should be able to find diagrams for your make and model on the net. Just remember to unplug everything power,water etc. before you start. Otherwise call an expert.
Good luck.
John
Posted on Feb 14, 2008
  • 4 Answers
Buy a new one smartass
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Sounds like ametal object in drum but there is nothing visible its making a loud banging noise
hello they usually make this noise sometimes a few thing to check make sure the washer feet are adjusted properly if ok .with the power off you could take the top off see if the 2 springs are attach either side of the washer sometimes the snap or come loose also have a look at the suspension legs make sure there tight or not broken hope it helps
regards
shaun
Mar 27, 2011 | Zanussi ZWF12070 Front Load Washer
The drum is moving front to back and making terrible noise
The retaining nut/bolt for the drum has come loose. Remove the back cover and check the drum axle and attachments.
Jan 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Sounds like something is knocking around in the back of the washer. On the spin cycle, the noise is very loud anyway, but it sounds like there is something banging around inside. The drum moves around...
ok open the door
make sure the thing is empty
try to move the inner tub
if you can shke it side to side anything but around
you have a broken spinner support
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Noise from drum
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this safe too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only .I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one cause I suspect.
Thank you for contacting Fixya.com
Aug 30, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Drum banging is it bearing when on spin
Aug 29, 2009 | Zanussi FLA1001W Front Load Washer
Loud sounding like loose parts when draining
possibly a coin or hair clip in the pump if not the propeller on the pump may be loose try locating the pump under the machine and try to romove it
Nov 11, 2008 | Kenmore 43052 Front Load Washer
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
Washing Machines Logo
211 people viewed this question
Top Washing Machines Experts
