Question about Royal 29546Y
Restoring Data back from factory settings
My Royal Organizer (DM5070) displayed two options, 1 and 2 and in error I pressed the wrong button, which put the organizer back to the factory or original settings. When this occurred, all data was lost or erased. Is there any way to retrieve or recover this data? Thanks.
    Genius:
  • 1,665 Answers
Unfortunately you can not retrieve lost data by yourself.
Posted on Feb 15, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 15, 2008
    It s better to forget about it as soon as possible.
  • 2,334 Answers
Is very unlikely to recover data once it has been erased from this organizer.
Once the device goes to factory default, everything in it is gone.
Sorry.
  • 19,396 Answers
Your DM5070 has a 256MB memory which store all information inside it. When you chose the option restore factory settings it flashes the memory, erasing all information and restoring initial data. As far as I know there is no way to recovery your lost data on this pda.
regards
  • Ginko
    Ginko Feb 15, 2008
    As far as I know Active File Recovery 7.3 Build 101 Supports FAT12, FAT16, FAT32, NTFS, NTFS5, NTFS+EFS file systems on Windows 98 / ME / NT / 2000 / XP / XP Professional x64/ XP Home x64 / 2003 Server x64 / Vista. I dont think there is a version for Royal dm5070 pda. Again: the memory has been flashed. It is a flash memory, not an hard disk or a magnetic support. If no backup has been done there should be no chance to recover lost data
    Brigadier General:
  • 3,614 Answers
Yes..! if i'm not get mistaken with the software i used before, maybe you can try this
hope it helps..
it's my pleasureto hear more again from you.
good luck.
micro
  • 1 more comment
  • micromaster
    micromaster Feb 15, 2008
    Otacon, got sure about that..?
  • micromaster
    but there was a chance, only if it's small. right?
  • micromaster
    we are here ** ginko** to find out what will happen next.. things can never be done without TRYING..
    cheers!
    President:
  • 1,944 Answers
I am sorry but there is no way to restore the data lost.
  • Damen Wong
    Damen Wong Feb 15, 2008
    When you select to put the unit to factory/original settings it wipes out everything (data). This applies to most electronic items.
  • Damen Wong
    If it was on a memory card then there would still be a small chance of recovering the lost data.
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
Tip
Visor Deluxe does not start
Hi.
The procedure below shows how to reset the PDA to factory settings after backing up all your personal data.
After backing up your data with HotSync, perform a hard reset, this will erase all applications and returns your device to its factory default settings.
To perform a hard reset:
1. Hold down the power button on the front panel of the PDA.
2. While holding down the power button, use a paper clip to press the reset button.
3. Release the power button.
4. You will get a message warning that you are about to erase all the data stored on the PDA, do the following:
Press the top scroll button on the front panel
to complete the hard reset and display the startup screen.
If you press any other button you will do a soft reset, that will not fix the problem. In that case restart the procedure.
5. After doing hard reset the unit will return to the initial factory state. All third party installed applications will be deleted, and setting will be reported to factor default.
Connect to HotSync and do a backup of the PDA, then do hard reset on Palm.
If the PDA is not detected by Hotsync, then there is an additional problem.
To troubleshoot problems given by third party application you do a backup, then rename the backup folder containing third party application data to Backup.old, and do hard reset.
After that you start restoring applications from backup.old one at the time, when one application jams the Palm, that is the responsible for the error message.
Procedure is described here.
Regards.
G.
on Apr 09, 2010 | Handspring Visor Deluxe Handheld
Disabled itouch
Try restoring the iOS device if backing up and erasing all content and settings doesn't resolve the issue. Using iTunes to restore iOS devices is part of standard isolation troubleshooting. Restoring your device will delete all data and content, including songs, videos, contacts, photos, and calendar information, and will restore all settings to their factory condition.
Before restoring your iOS device, Apple recommends that you either sync with iTunes to transfer any purchases you have made, or back up new data (data acquired after your last sync). If you have movie rentals on the device, seeiTunes Store movie rental usage rights in the United States before restoring.
Follow these steps to restore your device:
1. Verify that you are using the latest version of iTunes before attempting to update.
2. Connect your device to your computer.
3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
4. Select the Summary tab.
5. Select the Restore option.
6. When prompted to back up your settings before restoring, select the Back Up
option (see in the image below). If you have just backed up the device, it is not
necessary to create another.
7. Select the Restore option when iTunes prompts you (as long as you've backed up,
you should not have to worry about restoring your iOS device).
8. When the restore process has completed, the device restarts and displays the Apple
logo while starting up:
After a restore, the iOS device displays the "Connect to iTunes" screen. For updating
to iOS 5 or later, follow the steps in the iOS Setup Assistant. For earlier versions of
iOS, keep your device connected until the "Connect to iTunes" screen goes away or
you see "iPhone is activated."
9. The final step is to restore your device from a previous backup.
If you can not restore your device then you will need to go to recovery mode.
Placing your device into recovery mode:
Follow these steps to place your iOS device into recovery mode. If your iOS device is already in recovery mode, you can proceed immediately to step 6.
1. Disconnect the USB cable from the iPhone, iPad, or iPod touch, but leave the other end
of the cable connected to your computer's USB port.
2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the
red slider appears, then slide the slider. Wait for the device to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake
and Home buttons at the same time. When the device turns off, release the Sleep/Wake
and Home buttons.
3. While pressing and holding the Home button, reconnect the USB cable to the device.
The device should turn on. Note: If you see the screen pictured below, let the device
charge for at least ten minutes to ensure that the battery has some charge, and then
start with step 2 again.
4. Continue holding the Home button until you see the "Connect to iTunes" screen.
When this screen appears you can release the Home button.
5. If necessary, open iTunes. You should see the following "recovery mode" alert:
6. Use iTunes to restore the device.
Dec 26, 2013 | Apple iPod touch
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
How to hord reset nokia 1616?
Hi welcome to fixya.com.To hard reset your Nokia 1616 you just have to press *#7370# and press Dial. The phone will request the security code that is by default 12345. Please be aware that you will loose all the data in your phone, so you should backup all relevant information.
If you want to soft reset your Nokia 1616 you need to press *#7780# and then Dial. The security code is 12345. Once you complete this, your phone will come back to factory settings, but you will not loose personal data. Anyway it is recommended to make a backup before performing any of the mentioned procedures.Hope this answers your question. Please feel free to ask questions on fixya. Have a nice day. Bye
Mar 13, 2011 | Nokia 1616 Cell Phone
I have a ROYAL DM80nx organizer and need to know how to change the date and time on it.
press the time button and the press button at the bottom with a key on it. (it has 't.set' in grey writing just above). On the screen - at the top - the first letter should be flashing. To be honest I don't know what it means at the top but you can use the arrow keys to go navigate. The 1st line has the day at the right. The 2nd line has the date - YYYY - MM - DD. On the 3rd line is the time. A=AM, P=PM. HH - MM - SS (Seconds cannot be set but reset to 0 whenever the time is changed).
Oct 04, 2010 | Royal DM5070
Have lost my users manual.. baught new batterys and when i replaced them i lost everything except the day and date.. i have had this dm5070 for many years and it is the exact unit as shown above this...
Robert!
First see the FIXYA link below.
Robert, sounds like you need to get to your BIOS settings... different mfg. have different KEYS to press just as your ROYAL starts to start (or boot up).
Sometimes it's the F1 key... for others it's the ESC or Escape key and some use any ONE of the other "F Keys".
The trick is to GET THERE JUST as you see the FIRST screen flash ~ if not slightly before.
In the BIOS you should see a series of OPTIONS... DO NOT change *any* of them ~ except the "DATE AND TIME".
PS: It's the Holiday Season and WE give you permission to get yourself a NEW computer! At 73 ~ YOU deserve it.
Note:
Robert, your Royal looks like a older puppy... Just know MOST systems have a BATTERY that keeps your date and time SET... even when power is disconnected. It's a good idea to change that battery every 3 ~ 5 years OR you may find yourself adjusting date and time often. That battery is called a CMOS battery.
They are about the size and appearance of a US Quarter.
Anthony
Top 20 Royal DM5070 Questions Answers
Dec 14, 2017 | Royal DM5070
Where can I get an instruction manual for my royal dm5070?
Call the Royal Sales Desk at 888-261-4555 to request a manual.
Jul 02, 2009 | Royal DM5070
Casio BOSS 5300
I would suggest doing a "Reset". You will loose all your data, but at least you will be able to use it. You do a Reset by removing the bottom case, turning on the BOSS, them pressing the Reset button located inside.
Jul 21, 2008 | Casio Boss Business Organizer
Samsung Blackjack display error
This is a fairly rare problem, but it does happen with the Blackjack and other Windows Mobile devices.
First thing to try is:
Start -> Settings -> Display -> Home Screen -> (your carrier) Default
If this option or no options are visible, attempt to move right or left a couple of times (if you are in the list mode, move up and down) and then hit 'OK'
If this does not work, you will need to do a factory restore on your device:
WARNING - Restoring the factory settings on your device may cause the loss of all of your data that is not stored on the memory card or backed up elsewhere. Please back up your data before doing a factory reset and remove your memory card during the procedure:
From within the Software:
1. Start -> Settings -> More -> SECURITY -> More -> Reset
2. Enter '0000' and hit 'OK'
From the Powered off state:
1. Power off the device
2. Hold down the 'UP' navigation arrow while pressing the power button.
3. You will be presented with a 'format' menu, hold
Aug 18, 2007 | Samsung Blackjack SGH-I607 Smartphone
Royal 29546Y Logo
227 people viewed this question
Top Royal Computers & Internet Experts
Jaime Hernandez
Phillip Whisenant
Phillip Whisenant
Vladimir Frolov
Are you a Royal Computer and Internet Expert? Answer questions, earn points and help others
