FixYa.com
Tags:
HP LaserJet 1012 Printer
Refill Toner Cartridge for Laser Printer
posted by sfraibe2 on Feb 14, 2008
I have an HP 1012 Laser Jet, and the price of the toner cartridges is expensive. As a result, I am interested in trying to replace the ink in the toner cartridge once it is empty, as opposed to buying a new one, but I have never done this. Does any one have experience replacing ink in a laser jet toner cartridge, and can tell me what this entails.
Comment by sfraibe2, posted on Feb 15, 2008
I'm not sure there is a refill center in my area. It sounds rather straight forward using the melt and pour method. I suppose my main questions from this answer (and other research) would be how messy (or not messy) is it, and what type of ink do I need to buy?
I guess I'm resisting your warning to not do it myself. I've also visited a few other discussion forums where people seem to use the toner refill kits such as the ones that you sent, and they seem happy with the quality. I think the health issue, however, is a serious and real concern. But what if I just wear a painter's mask and do it in the garage? In terms of vacuuming out the waste, is this a question of health or the quality of the printing? Specifically, would you mind clarifying why I shouldn't do this myself? What am I really jeopardizing (if I wear a painter's mask), as it would save me some money and I think be better from the environment (though recycled cartridges would also be okay.)
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
EPIJAB
Rank:Guru Guru
Rating: 86%, 56 votes
I work for a company that does this and can tell you it is possible. Some companies do the drill and refill and some like mine actually take the cartridge apart and replace the drum and wiper blade.
You can buy the kits to refill your own. Usually, it just involves drilling a hole and pouring in the toner. This is the first I have heard of the melt and pour. Just be aware that eventually the parts inside will wear out and start to show image defects. You don't recommend reusing them more than twice.
Comment by EPIJAB, posted on Feb 15, 2008
Unless your refill mass quantities the health risk is not all that high. Wearing a mask is the way to go. As for how messy, it shouldn't be to bad with the toner, it will be sorta like working with flour.
Rating Locked! (?) sfraibe2 has rated this solution as Helpful
Solution #2
Thanks for Trying (70)
mediatecar
Rank:Guru Guru
Rating: 89%, 113 votes
Nobody has a clue how to refill a laser cartridge with ink. :)))
OK< just kidding, here it is:
First of all, laser-cartridges have toner (a fine black powder) and not ink.
Second: There are 2 methods to refill a laser cartridge: dismounting it to get to the toner chamber (involves a lot of tehnical skill) or the melt-and-pour method (see here http://www.urefilltoner.co.uk/), but you need the melting device.
But because from your question i see you dont know a thing about refilling, better go to a refill center.
Comment by mediatecar, posted on Feb 15, 2008
I just said that "laser-cartridges have toner (a fine black powder) and not ink."
Please do not attempt to refill your cartridge, this must be learned, the powder used to refill the cartridge (called "toner")is also dangeros for health, professionals have a vacuum claner to get all waste toner out of the cartridge before the actual refill, with special filters so it will not get into the lungs.
More, after 2 or 3 refills the drum must be changed, or evan the drum cleaning blade, this means dismount the cartridge, belive me, it's too complicate.
Where are you from?
If you still think you can do it, serch on the internet for the toner refill kit for your printer, there you'll detailed instruction for how to do it.
Example:
http://www.printertonerwarehouse.com/HP+LaserJet+1012.printer-cartridge.5753.html
http://www.tonerrefillkits.com/refill_products100.php
etc...
Comment by mediatecar, posted on Feb 18, 2008
OK, do it yourself. I was just concerned about your skills (no offense!) when i saw you ask how to refill THE INK in a laser cartridge, this is somehow like the rection you would have if someone would ask you what lamps he has to replace in a compute in order to make audio to work.
Hope you can do it without problems, let me know here how you manage to do it.
Rating Locked! (?) sfraibe2 has rated this solution as Thanks for Trying
Can you Help with these Printers problems?
HP laserjet 1012
Pap will not automatically feed... Answer This...
HP LaserJet 1012 Printer prints...
Replaced pickup roller,... Answer This...
paper jam
I printed without paper and... Answer This...
printer will not print...
printer will not print... Answer This...
Solid black pages Hp 1012
New cartridge, and updated... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
