Question about Samsung SC-D353 Mini DV Digital Camcorder
Damage lint hi there, i have a damged lint that connects to the side pice viewer, it is broken. How is it possible for me to order that part seeing that where i live her i is very difficult for me to get assistance so i'm the doing it my self kind a guy. please let me know how u guys can help me for that equiment is my baby toy thx in advnace oniel from curacao Nederlands Antillies.
  • 73 Answers
What model do u have . email me kndchaney@dejazzd.com
Posted on Feb 23, 2008
How to replace cords to door of dishwasher
Hi, You have to get access to both sides of the dishwasher, remove both sidepanels, Find damaged cord and order relevant part online, order 2 cords to replace both sides. To replace damaged cord ensure to close dishwasher door and unhook spring, replace damaged cords on both sides and connect springs back into place. Install both side panels to dishwasher. Done
Oct 17, 2014 | Belling Dishwashers
My phone will not turn on there is no water damage or any damage
Did you look inside the phone to see if the white dot is red? If it is read then somehow water got inside the phone. If it's still white, you might try a hard reboot. Hold down the power button until it powers off (don't hit the power off button) just hold down the button until the phone is off. Then reboot and see how it does.
Sep 11, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
I have a Sony camcorder, and cannot see the display screen. I can see through the viewfinder, but not the side viewer, that flips out, what is wrong??? kind of feels like a loose or broken...
Model No.? LCD or the connecting flexible connector is broken.
We can send you spare parts once you confirm the defective part and Correct Model no.s
sony@vsnl.com
Oct 12, 2013 | Sony Cameras
My ford escort zx2 serfinteen belt broke car died, pushed car to parking spot, removed belt pices, now car dose not want to start, tested battery, battery good 12.45 , turn key no power to anything
Sounds like a wire was broken by the belt somehow.
You have some fuseable links and large fuses that power the components on the car.
I would look around for a loose wire close to the belt side of the engine, and check the fuses for power.
Jul 18, 2012 | 2001 Ford Escort ZX2
We have model# Lgn1000PQhe dryer will light but before the cycle the heat shuts off
Hi and welcome to FixYa. I am Kelly.
This can be caused by several things.
1. There is not enough airflow through the dryer.
a. First check the outside thru the wall vent flapper for any signs of lint build up. (clean as necessary)
b. Pull the lint filter and then use a flashlight to check for lint build up on either side of the lint filter.
(Use a folded metal coat hanger and a vacuum crevice tool to remove any excess lint.)
c. Wash the lint filter screen with white vinegar and water. This removes any fabric sofener sheet (bounce) particulate build up on the screen. It may look clean but it can still be blocked.
d. Try running the dryer as a test with the rear vent connection disconnected. If it perfroms normally the ducting from the dryer to the wall is restricted probably from lint build-up
e. As you do step d. above place your hand relaxed in the airflow... it should push your hand slightly away from the vent duct connection hole. If it does not do this there is a problem still with internal airflow through the dryer.
1) Inspect the rear vent connection tubing as far as you can see for obstructions or restrictions
2) If after all of the above and you still do not have good air flow then the blower wheel / fan may have a broken hub and is not turning fast enough or it is missing fan blades.
f. GOOD AIRFLOW and still burner goes out
1) Possible flame sensor failure
2) Possible gas vavle solenoid problem. (weak coil)
That is pretty much it for the basics... If you give all of the above a try and you still have problems just repsond here and someone will get back to you. I also will get notified of any response.
Thanks for using FixYa.
Kelly
Jun 20, 2010 | Dryers
Broken Button
Hello Roinette,
It is unfortunate to know about that. However as you told that the left click button of the touch pad for you acer laptop has broken or damged, the only way to get it resolved is to get the laptop serviced. As the laptop touch pad and keypad is integrated directly with the mother board it is not possible to fix just that paricular button. The pad must be replaced. Get in touch with the acer technical support , they will replace the pad for you.
Thank you. Best of Luck.
Oct 20, 2008 | Acer Aspire 3100-1405 Notebook
BOSCH SGS6302GB
Hi nikkij
It is simple to put them back on. the plastic pices fit on the bottom of the hinges. there is a cut out where they fit in. when you look at the door at the bottom you will see the hinges and the cut outs, the plastic pices fit in the cut outs flat side in. hope this helps
Sep 15, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Maxtor Personal Storage - beeping noise
consult the authorized service cenetr of amxtor as they can recover data from damged hard disk . carefull while connecting to pc . as it can damage pc if circuits are broken
Dec 03, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Samsung SC-D353 Mini DV Digital Camcorder Logo
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
