Question about Maytag MMV1153A Microwave Oven
Microwave problem when oven is started it makes humming noise still cooks but I believe the fan is not kicking up to speed. I can see the fan turning but no air come out the vent above the door.
  • ffp104 Feb 17, 2008
    4 years old/ humming sound is more like a hum when it starts but never switches to that fan sound. fan seems to spin fast but no air comes out that hole on the top left left like when oven was working properly
    Scholar:
  • 90 Answers
Is this a new or used unit, and is the humming sound new? Can you watch the fan blade go around or is it going too fast to watch a blade?
Posted on Feb 16, 2008
  • Timothy Smith Feb 18, 2008
    If the unit still cooks alright, it is probably ok. The hum you hear is probably just the magnatron transformer mounting screws being not quite tight enough. This is not a problem, but causes the buzz or hum. Most likely if it is something more serious it will go out and there is not much to do about it until it does. Is there a filter in the unit that could be plugged not allowing the air to move through it?
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
Microwave lights and fans work but the food does not cook
If the microwave sounds normal, but not heating, then the magnetron is bad and needs to be replaced. If it is making a humming noise, then the diode is bad. I recommend that if it is the magnetron, ou also replace the diode.
Feb 10, 2011 | GE Advantium SCA2001BSS Microwave Oven
We have just purchased a Kenwood microwave/combination oven and are concerned there may be a problem. When the food has finished cooking and the microwave beeps it seems there is a fan or something still...
In most modern combination microwave ovens, if not all, there is a fan that comes on after use to cool the magnetron and cavity down. This is quite normal but if you still have doubts, contact Kenwood's web site and send them a question.
Hope this halps to put your mind at rest.
Nov 27, 2010 | Microwave Ovens
Timer functions, fan works, great humming noise, no heat. Magnetron??
If there is no heat at all, but you can hear the magnetron humming, it is probably bad. if there is uneven heat, the wave stirrer that distributes the microwaves around the cooking chamber may be bad. it will heat only one spot unless the wave stirrer is rotating.
Nov 20, 2010 | Maytag MMV5207 Microwave Oven
GE microwave model number JVM230WV 001 popped while cooking now when turned on it will only make a humming noise. Light comes on but no heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Making a humming noise when turned on and not cooking. I punch in the cooking time I would like and then when it turns on it makes a humming noise and does not cook.
From your description it appears that the Magnetron has failed on your microwave.
*Please be aware*
Replacing the Magnetron in a Microwave is a highly specialist job and should not be carried out by an unqualified person. Microwaves carry lethal levels of voltage even after they have been unplugged from the mains supply. The high voltage circuitry in this area of the oven is extremely dangerous and must undergo a discharging process before work can commence. The Magnetron itself is the main 'engine' of the microwave and operates under extremely high voltages.
For this reason I strongly urge you not to attempt this repair yourself but have it carried out by an electronics repair shop. The cost of this is likely to be prohibitive and you will need to weigh up whether this repair is economically viable or whether you would be better to replace the unit altogether.
Hope this helps. Thanks for using FixYa.
Sep 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Humming ge sapcesaver microwave
During operation, most of the built-in models have a panel that tilts out while the exhaust fan is on. When cooking is done, the exhaust fan shuts off and the panel retracts to its normal position. With the fan & microwave motor off, the hum is easier to hear. Look closely at the top panel the next time you hear the hum, and you'll probably see that it's retracting.
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Noise/humming while cooking; especially popcorn; intermitent on other food
Popcorn is heated by a metallic insert in the bag. This causes some additional power consumption by the magnetron. It is no cause for alarm.
Dec 19, 2007 | Kenmore 80412 Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
GE Microwave problems after HV capacitor replacement???
The rectifier diode could indeed be bad. But first I would want to know what value (in uF) the old one was and what is the value of the new one? If they're too far off, the difference in the capacitive reactance could throw off the "tuning" of the circuit. The uF value of the capacitor is optimized in relation to the other components used in the system. Of course, you'd also want to be sure your new cap is at or slightly above the working voltage rating of the old one, too.
Jan 04, 2007 | GE JVM2050 Microwave Oven
Maytag MMV1153A Microwave Oven Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
