Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer i'm still waiting on an answer from anyone that can help.my washer wont spin.it fills water,it does drain & as far as I know agitiate.I can turn the drum by hand but there is alot of play to it.with the lid switched pressed in it will not hand spin start. I need to know if thos is a easy & cheap fix or am I bewtter off buying a new washer???
  • 240 Answers
More than likely, you have lost your basket drive and clutch system. Its a pretty detailed job, having to remove the baskets, transmission, etc. Not usually a fix-it-yourself type repair unless you are really handy and have a decent amount of tools. The basket drive usually runs around $100.00, clutch kit around $40.00. Service charges could be from the low $70's to above $200.00 (Sears) in some cases. Let me know if this helped you out, or if you need further help. Thanks and good luck!!!!
Posted on Feb 15, 2008
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
417.43142300 Kenmore drains while trying to fill with water
try this the drain hose from the washer is stuck to far down the drain .allow only 8 to 10 inches down drain if the house drain is lower than top of tub it will do the same thing. raise the drain haundi24
Oct 27, 2009 | Kenmore 43142 Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 70 series will not agitiate - model 110.24722300
You Can Pop The Top off The Unit Like A Stove Top. If Your Not Familiar Grab A Big Flat Head Then Pry Up On The Top Edge Of The Dryer Where The Top Meets The Casing It Will Pop Off. The Lid Switch Often Clicks Just So You Know. Does It Spin Of Anything?
Jan 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore wont agitate or spin
The motor has a temperature cutoff. When the motor gets hot it switches off and won't go again till it cools. But something is causing the motor to overheat. Some overload.
Jul 25, 2008 | Washing Machines
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Here are the answers to your questions about my washer
Based on your answers your basket drive is out in the unit this is a Major repair $300-$350 or so parts and labor you will have to weight the cost of a new machine verses the repair how old is the machine??
Feb 13, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Robert Rankin
