Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
CAN NOT GET TIMER TO SAY A.M.
I thought I had the clock set correctly and then did a program for this morning. It did not start - when I checked the program it was p.m. - I can not see a.m. even though I move through. How do I ge to a.m.
I just purchased it yesterday.
Help!
I did call Cuisinart and they told me to unplug the unit for at least a half hour. I did unplug it for an hour and then attemptedd to reset the clock and a program. It worked. Evidently, it becomes confused if you try too many attempts.
Posted on Feb 15, 2008
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Hagar EG103 timerswitch when i set a program it says on but it has not switched on
Check if programs have conflict, such as ON at Monday, but OFF all days of week.
Check if wiring is correct: The imput voltage does not put power to the switching terminals. Add a jumper wire from input terminal 3 to COM terminal 6.
Check load rating of timer vrs load rating. For example 2300 watts maximum incandescent and halogen, but 400 watt fluorescent tubes, and max 500 watt CFL.
Some timers have minimum watt requirement, but is not apparent in the manual.
If timer clock keeps time, and can be set, then timer input is wired correctly with correct voltage
Copy following links for Hagar timers:
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/pdf/EG103E_103V_User_Instruction.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 21, 2012 | Hardware & Accessories
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
Hi - My Intermatic T101P3 timer motor stops after it turns off the pool pump. I have one start and one stop time in a 24 hr period. I have to manually start the pump at the timer in the morning,...
Sounds like the clock leads are on the wrong posts, or at least the hot one is. If if was moved to the load side then manually starting the timer will also power up the clock motor. As soon as the clock trips the off timer, the pump and the clock motor are both off. Examine the clock leads to the wiring diagram inside the clock box cover to ensure they are connected correctly. I bet you'll find one of the wires is misplaced.
John
Aug 31, 2011 | Intermatic T101P3 Pool Timer IndoorOutdoor...
I have a HB88RC Intermatic 7 day / 7 event timer. I have followed the "easy set instructions" I have program 1 set to turn on X-mas lights at 4:30 PM and go off at 11:30 PM. For all seven...
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
We have a Dynex 19" television. We use the "timer" function as a wake-up alarm in the morning. The set should turn on at 5:55 AM. Recently the unit stopped turning on automatically. I checked all the...
After cussing at the thing for a while to get its attention,
I thought the problem over and fixed it as follows:
I went into the setup menu and selected the "reset default option. The set went to blue screen. The next step was to rescan the channels. Then in the time setup menu I turned off the automatic time update. So far have not had any more problems.
Aug 03, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Setting the delay on the oven
To correctly proceed you have to know the format the timer program is working in. SO you need to know
1Time format IE 12 hour AM - PM or 24 hr military time 2If a day, date is required M-Sun...or IE Sat 12th of March...(some times this is not a peramiter needed)
With the clock and calendar set the delay time should require a "timed mode setting" prior to being able to set the timer. Once in this mode you will have 1 of 3 ways to set the time delay depending on how the timer is set up to read your instructions. .
1 the actual time of day it is to start (set in actual clock time like the equalivant of 3:05 PM or if in military time, 24hr clock 15:05) or 2 the actual delay time until the program is set to start (again set in hours and minutes 2:10 = 2 hours and 10 minutes from now) 3 also is the stop time, when you want to program to end (also set in the format the timer is programed to recieve instructions)
Also the calendar could be waiting for input as to which day to start the program
Jun 12, 2009 | Kitchen Ranges
Alarm clock radio feature
Before you do anything else, Cancel the Timer setting, which is activating the machine to start Playing in the afternoon. You will need the machine's Remote for this. On the Remote, Press TIMER repeatedly, while pressing SHIFT, till the Clock Symbol disappears from the Front Display. Now if you have to reset the Timer to play the machine at a different time - early morning, as you desire, follow these steps. First You have to make sure that the clock is set to the correct Time.Is it? Fine. If it is not,read trhe Owner's Manual and set it to the correct Time. Take note that you mark the AM or PM funtion properly. After the time is set correctly, You gotta set the clock to Switch On the set at a designated time in the morning. Follow the "Setting the Timer" instructions in the Manual to do so. Please do make the effort. I am here to help you, but I also do not encourage spoon feeding. You havta to some work yourself too. If you are still unable to do so, mail me at guptapravin@hotmail.com, and I shall send you step - by - step instructions Good Luck!
Sep 19, 2006 | Aiwa NSX-AJ310 Shelf System
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
48 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
