Go to http://www.youtube.com/watch?v=l6GRhsvP-og this will explain all its has worked for me twice just make sure you use a usb flash drive not a memory card it will take 10 mins to do its quite simple your guna need to re-flash the bios.
Let us know what you tried to fix it. Her is what I will do:
1/ try to start without battery only with power plugged on (sometimes it doesn't work without battery connection on)
2/ Measure with a voltmeter the power out from the battery
3/ Replace battery (cheap one on ebay)
If after that nothing happen the the motherboard is probably screwed...Sorry.
You can still sale it for parts..
Good luck and don't forget to rate.
cheers
Your laptop may still be under manufacturers warranty. check with the firm you got it from
