Question about Ovens
Ovens on cooker
How to reset the timer to get the ovens to work
  • kdalury Apr 04, 2009
    how do you wire it out?
  • 4 Answers
DEPENDS ON THE MAKE AND MODEL EACH TIMER OPERATES DIFFERENTLY, BEST SOLUTION IF YOU DONT USE THE AUTO FUNCTION IS TO HAVE THE TIMER WIRED OUT SO OVEN COMES ON REGARDLESS IF THE TIMER IS SET OR NOT.
Posted on Feb 14, 2008
My zanussi cooker isn't working after a power cut...even the timer/clock isn't flashing to reset wht can I do
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Apr 06, 2016 | Zanussi Ovens
Bypass a faulty timer unit on a stoves 720ef cooker. . . . My partner tried this today on my cooker and now there is no power to the cooker at all!! Is there a chance he's managed to do the wr
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Dec 16, 2014 | Stoves 720EF Electric Double Oven
Should I chuck out the cooker because the oven timer does not work?
Believe or not a lot of consumer items are this way nowadays. It sorta like push mowers where the repair parts, shipping, and labor cost as much as a replacement mower. It so expensive just get parts in from China and other places for the items they are just dumping on us that it is more cost effective to just to replace items that are out of warranty.
Oct 16, 2014 | Ovens
Is it an expensive job to replace the oven timer on my cooker?
I can do job for a lot less money or yes you can bypass timer, No Problem. David "The Famous Forry"
Oct 19, 2017 | Ovens
How can I reset my timer to manual on mylevc66w cooker
Well, not your EXACT cooker, but next one The lecv67, should be the same instructions.
Download here
http://www.leisurecooker.co.uk/Products/Download?filename=LEVC67.pdf
Page 20 and 21 refer to what you want.
Sep 16, 2014 | Ovens
The digital clock on my beko dv555 cooker isnt comin on and as my cooker was on timer now my main oven doesnt work either but my grill and hobs do
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Mar 09, 2011 | Ovens
Electric oven & grill not working no digital clock display
If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
They can be bypassed, but not recommended unless you know what you are doing..
If there is no display at all , then check to make sure you have supply to oven
Plz rate my solution.
Thanks.
Dec 16, 2008 | Neff U1661 Double circotherm super...
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
289 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
