Re: Keeps on giving the following message "Read...
Pls look again. i also experience it turn the lower knob downward to push the paper several times located om the tray on the right side. hope this help.
Hi! If there is a printer with door problems, this is one! Lets presume you have a paper jam, even if you dont see it. The bit of paper can be stuck in this three points: paper cassete, register sensor and fusion sensor.paper sensor gets damaged very often in this machine but the message will be " out of paper". The register sensor ( it tells the machine the paper arrived to the register roller and it can start cordinate paper movement with scanner movement, a question of syncronous efforts),lyes in the right cover, it looks like two small eyes, they must be cleaned. The fuser sensor, tells the machine the paper arrived there without problems but also says it already got out, once the paper comes out. the fusion must be opened to check this.
Now, this machine have problems in the door switch, you will see a square hole at the left side of the machine (presuming your facing it with the right door open turned to you) somewhere at half way.theres a switch inside that is actuated by a proeminence in the right door, once closed. If this actuator is broken the machine will keep telling you "close right door".If you see its broken, insert a small screw diver and press in, the machine will start to work and the message disapears, If the case, you have to "Reconstruct " the actuator, in order to touch and actuate the inner switch. Sometimes i do this just puting a screw through the plastic. Other choice is to order a new cover, these actuactors are very fragil. Also the latch that keeps door well shut.you wanna try to push the right door in, sometimes is enought. Hope i been helpfull, sorry my (bad) english. Come to me again if you got no improvement.
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. ([email protected])
Sounds like the 'Clear misfeed' symbol. Open the front cover and follow the pictorial diagram instructions to check your paper feed path for jammed paper. Remove misfeed, and close covers. This should reset your machine.
Clean the machine, the rollers also and follow these steps to clear out any paper jams it might have
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by
holding it with both hands and pulling firmly. The goal is to keep the
paper from tearing. If several pieces are jammed together, try pulling
out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or
ink cartridge and paper trays, close any doors you opened and turn the
printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
To fix the back cover removed issue, take a piece of folded up paper and stick it between the battery and the back cover. This will keep the battery seated.
Solution: Remove foreign objects from Rear Tray MP210
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
Power the printer off.
Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note :After confirming that the scanning unit support < 1 > is fixed into position, release your hands. Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
Close the scanning unit (printer cover).
Caution: Be careful not to pinch fingers when closing the cover.
Power the printer on and confirm that the printer operates normally.
Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows)
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
Open the Printers folder.
- For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
- For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
- For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
- For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
Click the 'Maintenance' tab and click 'Roller Cleaning'.
Remove all sheets of paper from the rear tray, then click 'OK'.
Confirm the following message, and click 'OK'.
Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
