Archos fm recorder
How to change the headphone socket on the archos fm recorder
  • 107 Answers
Buy a new headphone socket. if you want to change it. cut the wire then just copy the color coding of the wire to the new headphone socket. open the old socket.
be careful though.
I can't tell what color should be connected to the terminals. cuz' it depends to the manufacturer how they instal it.
sometimes they use black or none colored for the negative, common, or ground.
the left speaker colors yellow, red, pink, or sometimes gray.
the right may be as the left speaker colors.
or sometimes the manufacturer use multiple stranded wires.
so it's up to you.
Posted on Feb 14, 2008
We have a Tevion 45967, we want to just play records on it. Do we need to plug it into external speakers
Not directly.
You can:
play it via AUDACITY on your computer, or
amplify it from the line-out RCA sockets*, via your sound-card line in or a separate hi-fi amplifier with equalizer, or
use a headphone-splitter cable and amplify from that to powered speakers.
*The downside of RCA sockets is that your player's internal speakers still work.
Anything plugged into the headphone socket cuts out internal speaker. The headphone splitter allows monitoring via a headphone aaas well.
Nov 20, 2017 | Audio Players & Recorders
Why headphone not working in nokia 700
Its the complaint on socket of the device(mobile phone) , the rush using of earphones lead to this problem!
Contact your nearst nokia care , they will change ur socket in ur device... With a reasonable cost...
Enjoy the music and fm radio after this.....!!!!!
Buddies...
Feb 14, 2013 | Nokia Genuine Handsfree Headphones Wh-102...
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
I am having trouble watching a recorded video on my tv
You need to insert a video-out cable in the headphone jack and press the TV button on top of the device. onnect the cable to the TV and the Archos screen should appear on the TV
Jun 17, 2010 | Archos 604 Digital Media Player
How to connect Archos 5 to my Hi Fi to record audio cassettes
where your headphone would go this is where a mini plug to a "Y" rca plugs (plug into aux stereo)..adjust the volume and bass/treble on player....then adjust stereo to your likes
May 17, 2010 | Archos Internet Media Tablet MP3 Player
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Headphone socket broken on archos 704
Depends if the circuit board is damaged. If not and competent technicial should be able to repace the socket. If the board is damaged it will need replacing, unfortunatley this is coded to the hard drive so it is only possible if it is performed by Archos
Jan 26, 2009 | Archos 704 WiFi Digital Media Player
Archos 604 (not WiFi) connection to TV without the DVR station
HI, bought the following off ebay and they worked just fine. I to thought that the socket on the right side was audio only. Can't get a picture via my DVR (may be a fault) however this item works great.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=370172642094
Jun 06, 2008 | Archos 604 WiFi Digital Media Player
 Grubhead
Grubhead
