Question about Hotpoint RB757 Electric Kitchen Range
Burners wont come on.
Hey, I have a hotpoint electic stove I believe the model above. Anyways, 3 days ago we had a power-outage and now when i try to use the stove, the oven works fine, with all features, when you turn it the light goes on, etc. But now when we try and use the burner's, no-lights come on and they do not work(for all 4). It was working fine before the power went out. I am not sure what I need to replace and have a very very tight budget. Please help =)
  • joshflames Feb 14, 2008
    Hey, I checked the power outlet, unplugged it and plugged it back in, it is a big 4 prong plug. all lights went off, when I turned back on, again only the Oven worked, timer's, etc. but all 4 burners will still not turn on not even the lights
  • 4 Answers
At least one of the wires are eroded. get them replace.
Posted on Apr 15, 2009
    Master:
  • 619 Answers
Hi , try to check the power outlet , posible recock the breaker , check also the piower cord test with continuity tester both end of cord (diconnect before you test ) switch on knob if tester response , try to connect to power outlet test the electric stove.
Posted on Feb 14, 2008
  • leo2 Feb 15, 2008
    Hi , is there any reset button or fuse box behind try reset.
    this unit is 220 volts one of the line doesn't have power.If you have volt meter or multitester set to 250 volt test two hot wire if tester will read the current is good but will not read something wrong with the line.
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint electric stove burners wont heat up
Water ingress has taken the trip out i expect. If only clean water, it may dry out and then you can replace the fuse/breaker. If in doubt, employ a service engineer.
Dec 21, 2017 | Kitchen Ranges
Glass stove top error message wont go out, wont turn on?
What is the model number of your unit?
What is the error code?
Nov 22, 2012 | Kitchen Ranges
We have a Tappan gas range. Don't have the model number; it was in the apartment when we moved in. It is over ten years old. It has electronic ignition. The top burners all have orange-yellow flames...
Sorry to read about your problem, I hope this helps you out.
i would take all units out and clean them..clean all holes in the burners.
since you have the problem on all burners..air/fuel is not the problem at the adjustments..you may have a gas regulator problem
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Tappan MGF500PBW Gas Kitchen Range
I have a Kenmore Elite Kitchen stove top (one with the burners underneath a glass plate). Model number: 911 99004990. I believe it was purchased close to or around March of 2000. The problem I have with...
I have the same problem with ours! Our 2 small burners don't work at all and the 2 larger ones only work bright red hot. I called Sears and they said there is no recall on my particular model, but there are tons of recalls on other models. The problem is with the venting from the oven doing damage to the wiring (shorting them out maybe?). We're trying to find someone who knows anything about this and if we can get it fixed as our stove is only 3 years old.
Nov 15, 2010 | Kenmore Kitchen Ranges
Hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Jul 26, 2009 | Hotpoint RB757 Electric Kitchen Range
RB525 Electrice Range
You have an electrical fault in the connection to your stove or in your home. I believe that the neutral connection that is one of the three or four wires connecting your stove is loose or lifted off. Get an electrician in to solve your problem.
Mar 07, 2008 | Hotpoint RB757 Electric Kitchen Range
Burner works intermittently
You have either a bad burner or a bad control for same, or bad connections.
With power removed use a pair of pliers to crimp the connections (after cleaning the ones on burner) going to the burner.
Jun 17, 2017 | Kenmore 91112 / 91114 / 91117 Electric...
Hotpoint RB757 Electric Kitchen Range Logo
403 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
