Washer/dryer combo electrolux
The machine washes well but does not dry completely on the first run (even when set to extra dry). It needs two runs of drying - three in the case of towells - I knew I should have bought a Miele (the saving in price is no substitute for sattifaction
  • paddy0725 Sep 22, 2008
    We have an Asko WCAM1812 washer/dryer combo. A normal load takes 4-5 cycles to dry (10 hours!) and the heating element gets clogged with lint...even the repair man says that he has a lot of trouble with this model, and cannot find the problem.
    Genius:
  • 1,554 Answers
Your filter may be clogged
Disconnect the AC plug
Remove the bottom front access panel (3 screws on bottom front lip)
there you will see the filter access , have rags ready for extra water ,check the pump impellers that they freely move.
Posted on Feb 14, 2008
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
Malber WD1000 dryer timer starts running immediately when set, even in the middle of wash cycle
Call in the troops! You need to have the controller panel opened and checked for excessive lint and dirt. There is a short or two in that mess!
Dec 26, 2012 | Malber WD1000 Front Load Washer/Dryer
Clothes not dry
check your dryer venting from the machine to the outside vent,if they are plugged it will not dry properly,then make sure you have good air flow to vent on machine,if not dismantle and clean lint from inside machine,these are inexpensive fixes,then it could be a cycling switch or the humidity sensor bar that needs replace
Jan 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
LG Tromm DLE Dryer never dries my clothes when the cycle is done
ok there,first the clothes must come out off your washer well spun,or dryer will work extra hard/long.next you dry a load with out ducting to elimanate your house venting[you wont hurt a thing]most off the time thats it![house]if still bad and you know your dryer is cleaned out then its an electrical problem.will go ther after you check the above.God bless.please help with my ratings if i have be helpful,tom
Jan 02, 2009 | LG WM2688HWM TROMM SteamWasher
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Hard towels
If you are drying your towels outside they will always be hard no matter what you try........ Drying them in the dryer is the only solution to that problem........ I have tried everything else and the dryer is the only thing that works..... Hope this helps
Oct 19, 2007 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
