Question about Toshiba Satellite M30X Notebook
THE LAPTOP WILL NOT START PROPERLY
WHEN YOU START THE LAPTOP TOSHIBA SATELLITE M30X THE BLUE LIGHT TURNS ON, BUT THE COMPUTER DOES NOT START, THE HARD DRIVE LIGHT DOESN'T FLASH AT ALL
  • ladymae May 01, 2008
    I have the the Toshiba will not start, the green lights come on and windows xp sign comes up them it gives choices of normal start, go to when it started properly,etc but none of those work, it just continue to act like its starting but gives media failure, boot failure
    Novelist:
  • 123 Answers
The solution to your problem is probably not the monitor, follow these steps:
1. Connect and boot your computer with 2 different monitors.
2. If it does'nt work with either of them the problem is from another computer component.
Posible Problems:
1. Your video card may be damaged or moved from it's slot.
2. Your proccessor may be damaged.
Posible solutions:
1. If you have computer hardware knowledge open the case
2. Remove the Video card.
3. Insert it back or insert another video card from a friend.(if it works with your friends card, obviously the video card is the problem)
4. Restart your computer and see if it works.
Now if it does'nt work after that you will have to replace your proccessor with one that works, from a friend, because you say your computer boots but if your monitor doesn't work you don't know for sure if it boots corectly.
The steps above are only for people with hardware knowledge, if that is not your case you should contact a computer service.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 16, 2008
Coffe spill now screen on lap top not working
No magic fix here Philip. The only thing to do is immediately remove ALL power, AC adapter (Charger) and Battery, and open the laptop up, remove the CMOS Battery, (RTC Battery), and dry it out THOROUGHLY.
After you are SURE all components inside the laptop are dry, reassemble.
Install the Battery, then the AC adapter.
Plug into power. WAIT 1 minute, turn the laptop on.
[ On ships they use old coffee to clean the deck. It has powerful acids in it. Don't get your hopes up in otherwords ]
1) http://www.irisvista.com/
(Read the entire page )
2) http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
3) http://www.irisvista.com/tech/laptops/ToshibaM35X/Satellite-M35X-display-1.htm
4) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the heading that starts with - Satellite A10. (A10 in blue)
Drop down to the fourth line (L655), and scroll across to - M30X
Click on the file name M30X.
(The Toshiba Satellite M35X-S161 Notebook PC, is part of the Toshiba Satellite M30X series of Notebook PC's )
After you click on the file name (M30X), it may take up to 30 seconds before the first page comes up.
A) Buy and wear an ESD wrist strap. Average cost is around $3 to $6.
Connect the alligator clip to a good ground source.
(Electro Static Discharge)
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
IF, the computer is still good you need to give it a fighting chance.
B) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
There are MANY screws that look VERY similar to other screws.
DO NOT mix them up.
C) Make a personal record as you disassemble.
Make notes, and drawings. (Legible)
Use a digital camera, or video camera if available. Use good lighting.
It's nice to have a personal record to refer back to, in case you are interrupted.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | Toshiba Satellite M35X-S161 Notebook
Need manual for toshiba m30x laptop
Scroll down and click "Download the Manual"
http://www.retrevo.com/support/Toshiba-M30X-S181ST-Laptops-manual/id/614ci469/t/2/
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | Toshiba Satellite M30X-S181ST Laptop
I Have Toshiba satellite M30X PC Notebookm. I have a problem with my usb cann't detect any port flash card, mouse, webcam, I have window xp sp 2 please Help,
HI there i am sure your laptop is virus infected. I was faced the same problem. After that i format the OS & again install that. So i suggest you the same thing. Thanks.
Apr 03, 2010 | Toshiba Satellite M30X Notebook
My system refuses to boot
You could have a faulty hard drive, reseat the hard drive, if it still doesn't work take it out and connect it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer sees the hard drive and see the contents of the external drive the the hard drive is OK then you could have a faulty disk controller or Windows needs to be reinstalled again.
If you cannot see the hard drive then it is dead and you need a new one.
Apr 03, 2009 | Computers & Internet
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite M30 - Power Problems only boots when in vertical position
These are known to have a grounding problem between the speakers and mainboard - They were actually sued and eventually settled to extend the warranty. unfortunately the special extenstion program ended a few months ago and toshiba no longer will fix this. The workaround is to add shielding to it.
See this link about it:
http://www.laptoprepair101.com/laptop/2006/04/06/satellite-m35x-a70-a75-lockup-freezes-reboots/
If that doesnt fix the problem then you may have motherboard problems and at that point it would be best to part this laptop out and replace it.
Dec 21, 2007 | Toshiba Satellite M30X Notebook
Toshiba Satellite turn ON problem.
Remove the battery and then try to run your laptop direct from the mains supply, if this works it proves your battery is NFG and you need another.
Mark
Oct 16, 2007 | Toshiba Satellite M30X Notebook
Toshiba Satellite M30X Notebook Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
