Question about Meade DS-2130ATS (250 x 127mm) Telescope
Automatic leveling won't work
I've suddenly experienced a problem with the LNT. When my telescope tries to fine level, it slews down until the body of the telescope strikes the mount. I'd appreciate any insight you can give. It worked fine one night and quit the next.
  • 3 Answers
You can try moving the tube back from center a bit, rotating it also helps. The tube has become magnetized
Posted on Jul 25, 2010
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
CG5 is brand new-not 30days old yet. Mount slews before a star is selected for alignment and continues to slew about the RA until power is cut. What is wrong. Tried 2 different power sources and factory...
You should return the scope under warranty-- however a bad power supply-- and or a bad hand controller cable can cause these symptoms called a "runaway slew".
Get a separate 12 volt power supply and the proper cigarette lighter style power plug.
Feb 12, 2011 | Celestron CG-5 Mount Telescope
While trying to do the initial alignment the telescope says slewing to Vega, but when it stops it is nowhere near Vega, Its almost 180 degrees out. some help would be very much appreciated The telescope is...
All GOTO scopes have specific setup procedures, usually:
1. Level the tripod
2. Point the scope NORTH or in the HOME position.
3. Center both alignment stars
etc etc
Read the manual and follow the instructions exactly.
Jan 11, 2011 | Tasco Optics
Leveling sensor seems to be inoperative, tube continues to slew along vertical axis until I have to turn off the computer to avoid damage. I have replaced the 3 volt battery in the Smart Finder, which, I...
Probably your hand controller cable is broken. First thing to try is a new hand controller cable.
Also check the small watch style battery inside the LNT module.
If a new cable and a new battery do not fix this then it an internal circuit gone bad. Only Meade can repair this:
http://www.meade.com/support/index.html
Try the new cable first.
Nov 28, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
Problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Calibrate sensors on Polaris
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Aug 30, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
Celestron nexstar 8 i series alignment trouble
use the rewmote that came with the telescope and go into setup under telescope and push enter when it says calibrate motor
Nov 06, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Celestron nexstar 11" gps scope
Be sure that the Azimuth Axis is Lock, you migth want to try and move the telescope in the Azimuth to make sure it is it is locked. Be carful not to force it. I have seen on some post where the locking part of the Azimuth somtimes breaks. and the Azimuth Axis will just spin freely Locked down or not.
May 19, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
Apr 06, 2008 | Celestron NexStar 130 SLT (306 x 130mm)...
Meade DS-2114 ATS LNT
Also had the problem. I found that the LNT did not find north unless the bottom of the Smartfinder is close to parallel with the ground.
Oct 11, 2007 | Meade DS-2114 ATS (325 x 114mm) Telescope
Meade DS-2130ATS (250 x 127mm) Telescope Logo
69 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
