Cars & Trucks Logo
Posted on Jan 23, 2010
2003 dodge ram diesel 5.9 cummins, auto transmission cooler
2003 dodge ram diesel 5.9 cummins transmission cooler problems, The cooler was water lines and transmission lines to the cooler and it started leaking on the inside and got coolant in the trans and a new is like $800 from dealer is there any aftermarket coolers that will work for this and can I just put the water lines together and relocate the trans cooler to front
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2779
Points
Did you ever get a cooler for cheaper pice
Anonymous
Level 1:
New Friend:
  • Posted on Nov 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2779
Points
I just bypassed mine completely trans shop wont warrenty if i put one back on it
2012 Dodge Ram 3500 with Cummins diesel. The truck performs normally with a full fuel tank. At approximately 1/3 fuel level, the vehicle begins to lose power and it begins to blow black smoke under load....
Assuming the fuel tank is breathing ok and there isn't a suction preventing the full flow of fuel, the tank is clean inside without water or sediment and the filters are clean, I only have one thought about your problem.
The fuel tank and the fuel in it is an essential part of the cooling system - the fuel return line carries excess heat from the fuel system back to the tank to be dispersed. A general rule is don't run less than a quarter full except on very short journeys or excessive wear will take place on highly stressed fuel system components.
This is more important with some designs than others and as many manufacturers utilising common rail diesel systems now fit fuel coolers it obvious they believe cool fuel is important.
This becomes more important when the fuel is a blend of diesel and bio-diesel, known to be a source of problems with the tight tolerances used in electric diesel injectors.
If your truck doesn't already have a fuel cooler I suggest you fit one.
SE. How do I remove transmission oil cooler line?
How To Install Replace Transmission Cooler Lines 2001-06 ...
? 5:45
https://www.youtube.com/watch?v=SFEXmxxBMK8
Oct 31, 2013 - Uploaded by 1A Auto Parts
How To Install Replace Transmission Cooler Lines 2001-06 ... In this video, 1A Auto shows you how to remove, replace and install leaking or broken Transmission Cooler ... How To Install ReplaceDo a Front Brake Job 2001-06 Chrysler ... 2003 Dodge Ram 3500 trans cooler replacement how to 11-24-12 ...
Search DODGE MAGNUM Cooling > Transmission Oil ...
www.factorychryslerparts.com > ... > Transmission Oil Cooler, and Lines
DODGE MAGNUM Cooling > Transmission Oil Cooler, and Lines. ... Please let us know what we can do to achieve this goal. ... Our inventory covers the following years of MAGNUM: 2005, 2006, 2007, 2008, ... Click X to remove the keyword.
Leaking Transmission Cooler Line Replacment Recommendations ...
www.dodgeintrepid.net > ... > General Discussion (First Generation)
Froze block on 02dodge diesel replaced 1freeze plug @oil cooler cover plate water still in oil . Was cooler busted?
sounds as if something else gave out when got frozen ,have to do a strip down an check for cracks etc
My 2006 2500 dodge ram is having shift problems in 2nd gear only. The truck has a Cummins and an auto tranny. It holds in first too long, then when it shifts to 2nd, sometimes it goes back to first then...
I had the same problem, after 26k miles and replacing the computer, and many other parts on the truck transmission they replaced the tranny....same problem. In short, and another tranny they found small alum shavings in the tranny cooling system...they then replaced all lines, coolent and tranny radiator (cooler )with another new tranny....problem solved. It was the tiny metal shavings in the tranny cooling system that continued to circulate the system.
2003 CUMMINS STALLS BELOW 1/2 TANK RUNS FINE ABOVE 1/2. REPLACED IN TANK FUEL PUMP MODULE STILL HAVING SAME PROBLEM
Just a suggestions but...
Check fuel filter.
Also add some fuel conditioner (e.g. HEAT for diesel) to get rid of any water that may be in your system.
1999 RAM 2500 TURBO DIESEL TRANSMISSION SLIPS @45 MPH
Most Likely Overdrive Lockup Problem--Can Be Function Checked With Scanner.
2003 Dodge Ram 2500 diesel 4x4 wiring diagram
TPIM PROBLEM , MUST HAVE COMPUTER FLASHED AT DEALERSHIP
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
