Goodmans LCD TV - No power
Had a Goodmans 26" LCD HD TV just over twelve months and now will not switch on. No power light. Tried checking fuses in plug and connecting on different socket - no joy. Surprise surprise neither Goodmans or tesco want to know. Assistance gratefully accepted as this cost me 350 UK Pounds and for twelve months wear I dont consider it value for money. Ta
  • Anonymous Jan 08, 2009
    i have the same problem
    Habit-Forming:
    New Friend:
  • 9 Answers
Probably power supply
Posted on Sep 21, 2017
    Top Expert:
  • Televison & ... Master
  • 12,962 Answers
Sounds like a power supply issue.
TV Parts Universal TV Stands DLP Chips ShopJimmy
  • 213 Answers
SOURCE: lcd shadow
you need to call acer you have a bad lcd sceen. i juct di one the sceen was fault.
Posted on Mar 30, 2008
IrishDruid
  • 2712 Answers
SOURCE: Goodmans LD3250HD LCD TV: No
You can buy a replacement PSU from HERE.
But these try these troubleshooters first:
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
IrishDruid
  • 2712 Answers
SOURCE: phillips lcd tv not switching
1. First, make sure the socket at the mains is working, try a different appliance to check. Next, try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
IrishDruid
Posted on May 06, 2008
volto
  • 101 Answers
SOURCE: can not tune in my
If you are trying to view TV channels, you might have to run a channel scan, check your user manual to see how to do a channel scan. Or just go into the menu and I'm sure it is there under channel setup or some name like that. I hope this helps you.
Posted on Jul 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: my big screen tv
Those are the two 5amp pico fuses that go out when the convergenec Ics go out on a mitsubishi. You can get the ICs and pico fuses at the following link. If youre not sure which ICs you need leave them a email with your model nuber.Heres the link
http://servicemanuals.vstore.ca/
Posted on Sep 01, 2008
Ns LCD 26-09 TV not powering up
LCD TV repair - Samsung LW20M21CP not powering up ...
? 25:30
https://www.youtube.com/watch?v=zxqDLDNuCfw
Jul 8, 2013 - Uploaded by RetroGameModz
This is a documented repair of a Samsung LCD TV that I got for cheap. It was listed as not working, which is ...
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:23
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
Samsung LCD TV Repair - TV Won't Turn On - How to Replace ... or if you have standby and the TV will ...
MOST COMMON REPAIR FOR LCD - NO POWER - YouTube
Dec 02, 2015 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Power light no bot it is dade
it sounds like the Power supply board.
I'd check the fuse, check A/C voltage, D/C voltage....BUT
most likely it's the capcitor or resistor.
check for bulging capacitors and if u don't see any test the resistors.
Jan 07, 2012 | Philips 26PFL5322 26 in. LCD TV/HD Combo
I have a 26 '' wide screen lcd tv by goodmans the standby light comes on but nothing else happens what could this problem be
hi there.most probably faulty capacitors on the power supply...most certainly if the issue has got slowly worse over time,to the point where the set will not come on at all..not an expensive repair if thats the case..
steve
Sep 13, 2010 | Goodmans Televison & Video
Tv wont come on
Don't mean to state the obvious but have you tried changing the fuse? There might also be some sort of internal protection device (fuse/circuit-breaker) that may need replacing/resetting.
Jan 02, 2009 | RCA L26WD26D 26 in. LCD TV
Dell w2607c
Had same problem too with my w2006c. Died after 6 month, replaced, then died after 8 month !!  Patrick Québec Canada
May 08, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
LD3750HD
goodmansld3750hd, last comment as guest is now signed in as baldwin1972 hope i get a response
Dec 06, 2007 | Goodmans 257NS 20" TV
Goodmans 27 inch LCD
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Jun 09, 2007 | Goodmans W280NS Television
Televison & Video Logo
350 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
