Question about Pyle PLTDF25 Car DVD Player
Pltdf25 dvd player troubleshooting
My dvd player is beginning to scramble the picture and the sound is jumbling like a scrambled signal..What could this be and what can possibly fix it. It is properly secured and i use the cigarette lighter adapter for power so that it doesn't power on all the time while i am driving.
  • Pyle Master
  • 19,396 Answers
Try using aDVD/CD cleaner disk to clean the lens.
Posted on Feb 14, 2008
When I try to play a DVD through the player the on screen picture has a scrambled look sort of like when your DIrectv signal begins to go due to a storm. I changed players and tried a different
A few questions for you that might narrow down the issue.
Where is DVD connected at?
Have you tried it on all rear inputs?
Where is Direct Tv connected to at the set and does it work normally?
If input it (the player) works with something else connected (rules out the input used) then I would suspect some setting in the players (identical model brand?) is set wrong.
May 20, 2012 | Toshiba 53HX71 53" Rear Projection...
Why is picture scrambled on my memorex dvd mvd2016
The MVD is a progressive scan DVD player if your TV is 1080i or shows interlaced images only and doesnt have the option for progressive scan this would be an issue. I would suggest trying this DVD player on another television first. Also what is the model of your television?
Another issue is if you have and HD TV and are hooking up the A/V jacks to the HD component inputs this would also provide a jumbled picture. It would be a good idea to check and make sure that the A/V cabled are inserted into the correct input.
May 05, 2011 | Memorex MVD2016 DVD Player
When I am watching a DVD, the picture messes up and is replaced by scrambled colors (noise) and then the picture returns. It does this periodically while I am playing a DVD. It can happen while the DVD...
This is most likely happening because your tv is upconverting the dvd signal to be compatible with your hdtv. If your dvd player has no upconverting feature of its own then it is more likely to happen. It's just your tv trying to compensate for the low quality signal coming from your dvd player resulting in intermittent scrambling or "noise". You should try to invest in a blu ray player when possible.
Jun 26, 2010 | Vizio SV422XVT 42 in. LCD HDTV
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
Installed dvd player , sound and picture is great, but it is black and white only! Any suggestions?
yes , go into your setting and make sure its displayed in PAL uk or ntsc for usa format.any other and youll see scrambled picture or black and white one ,
Jul 06, 2009 | Sony DVP-SR200P DVD Player
Screen distorted,cannot watch dvd or vcr
If you are located near a tv station that is broadcasting on the same frequency that your dvd player is trying to use, you will pick up some of the stations' signal that will cause some video ( and sometimes audio) interference. To remedy this you need to set the dvd player to use another frquency (channel). To do this there may be a small switch on the back of the unit or you may have to do it through the players' programming menu where you would look for something like 'output channel select'. I hope this helps :)
May 27, 2009 | Samsung DVD-V5650
Scrambled picture with DVD or Video Game
You have a bad digital board. Expect to spend some serious money to repair this.
michtech
Feb 20, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Sound with a scrambled picture
you have routed something thru a vcr or dvd player you can not have a vcr plugged in to another vcr or dvd player or the other way around this is done to prevent copying of dvd's if you need any other help feel free to email me a fixya@whypayforhelp.org
May 23, 2008 | Philips 60PW9363 60" Rear Projection...
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Pyle PLTDF25 Car DVD Player Logo
160 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
