Question about Health & Beauty
Snow shovel's edge worn down --who sells replacement parts
Snow pusher by Craftsman The edge of the snow pusher has worn down to the metal that it's connected to. I want to unrivot it and put a new edge on it. Where can I get a part from?
  • famousamos Feb 14, 2008
    The part I'm looking for is made for a snow shovel, the edge that touches the ground first, pushes the snow and glides the shovel over the ground. Who sell's it and where can I get that part from.
You can find a generic part here
http://yeomanandcompany.com/
Posted on Jan 28, 2011
No drive gears
ok ther is clutch Disc and it,s worn out need to replace it or the drive gear is worn look for broken rubber ring
Feb 03, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Tip
How to build a backyard igloo!
Backyard igloos are easy and fun for kids. You don't need a large amount of snow, either. A few inches can be shoveled into a pile that's large enough for a kid to crawl into, but you need to be careful to make sure that you make it strong enough that it won't collapse easily.
Start out by piling the snow a couple feet high. Three feet is about as small as you can go, but that works well for most kids. It can be as big as you want, though.
After you pile it up, use a watering can to sprinkle the outside with water. It should be cold water, since hot water will melt the snow more than necessary. Make sure you cover the entire outside of the snow pile. The water is the key to making it strong.
Wait overnight for the water to freeze, and then use a shovel to scoop out the snow on the inside. Make a hole in one side with the shovel, and then carefully shave off the snow on the inside until you are close to the edge.
That's it! If the kids want, they can scrape out the snow on the inside with toy shovels, too. Overall time to do a small one this way is just an hour or so, not counting the overnight freeze.
on Jan 15, 2010 | Sport & Outdoor - Others
I have a Mamakiddies 3 wheel jogger all terrain push chair, there is a bar that goes under the basket but it has dropped off, the metal has worn through as it was so thin and is in a position where it...
I fixed one of these for a friend a while ago. I've put a solid piece of wood between the two down pipes by screwing it on. I just had to shape the ends of the wood so that it takes the round shape of the pipes. I did this but putting plywood bits on the sides.
Oct 02, 2013 | Baby Gear
Toro shovel snow is noisy
Something may have gotten bent. Check around the moving parts for signs of damage or signs of scraping
Feb 14, 2013 | Toro 12" Electric Shovel Snow Blower
How to assemble polar tuff snow plow pusher
hoe do i put together a polartuff
Jan 07, 2012 | Watches
Have a craftsmand 24" snowthrower
If the motor runs well, the two most common causes of this are the drive belt is worn and/or the shear pins are broke.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission. It sounds like you need to inspect the blower belt.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Replace the belt if it is worn, stretched or frayed
The shear pins are located on the auger in the front of the machine. Your newer Craftsman has four. If you don't now about them look in your operator's manual for the location. You need all four for the snowblower to work well. Replace the missing ones.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman Garden
Changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
Your Craftsman manual will show you step by step how to change th belt.
Jan 13, 2011 | Craftsman 16" High Garden Tractor Snow and...
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE - RAISE REAR UP AND WHEELS DO - AUGER WORKS IT JUST WON'T MOVE
well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
Feb 02, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Health & Beauty Logo
1,627 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
