System Restore. I was wondering what systerm restore is and what it does. if i did to system restore on my computer,what would it do? would it delete files of my computer? Help Needed Reply Soon x
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore optionif it is a hardware issue the system restore might not work hope this helps you
Well there are several ways to approach this, 1st you can use system restore, to take your system back to a date that it worked fine, to do that go to the start pearl in the search bar type in system restore, click the Icon for system restore it will give you a calendar with several restore points that your computer has saved along the way. your system will go back to those exact settings, now if this is a virus issue, that is beyond system restore then a complete factory default is in order. Depending on what type of computer you have some have build in restore partition that are build in your windows OS. if thats the case simply hit F8 during start up and choose repair your computer and them choose restore to factory condition, this will delete any files you have on your computer and restore it to out of the box condition. System restore will not delete your data but, often restore points themselves are corrupted, my recommendation is to back up your files and do a complete factory restore.
Hope this helps please feel free to ask any follow up questions you may have on this thread.
Take care :)
You can try two things.
First: System Restore
- System restore will restore your computer on an earlier date/time. you can restore your computer the time before you accidentally delete your webcam. to go to System Restore
Start>All Programs>Accessories>System Tools>System Restore. (then Select a date/time that the driver is still installed)
Second: Downloading the driver from Manufacturer's Website
-you can try to search for your webcams website and look for the download page.
Try going to Programs->Accessories->System Tools->System Restore
Go back to before you began removing the programs. Also, remember whenever removing programs always use the uninstall feature, just deleting them can leave a lot of junk in your registry, cause possible corruptions and lead to sluggish PC performance.
you can restore this file in some way by doing system restore, system restore, will actually restore your computer from its previous setting. that includes your file
( this is one of the many ways)
To access the System
Restore Wizard, click Start, and then click Help and
Support. Click Performance and Maintenance, click Using System Restore to undo
changes, and then click Run the System Restore Wizard.
Creating a restore point can be useful any time you anticipate making
changes to your computer that are risky or might make your computer unstable.
you need to restore from previous date then follow what the computer says, then see what happens...
Go to the iRiver website, and see about getting a firmware upgrade. Most mp3 player companies can not restore the player's software using a firmware upgrade or reload, but some of them can. Once the system files are missing/deleted, if the firmware upgrade/reload does not resolve the problem, then the player is history. Hopefully, iRiver's upgrade will resolve that issue. Good luck!
No, windows backup will only restore your data, for example My documents, Desktop, User settings, and Outlook data. To restore the system you will need a windows install disk, or if your computer has a restore partition(like many dell, packard bell etc.), you can use the restore windows utility from partition.
