My PDA keeps freezing and the only way to reactivate is to do a hard reset.
Any advise would be most welcome
Hi here are the links to n35 rom, but I am afraid they deleted uk versions, have a look
http://csd.acer.com.tw/SI/Download2.nsf/HandHeldWeb?OpenView&Start=1&Count=240&Expand=3#3
and here are general instructions:
first go to ftp downlad site (originally ftp://ftp.acer-ee.com [if you're from Europe] or ftp://ftp.acer.com from USA.)
then use an SD card at list 64MBs
!!! FORMAT THE CARD VIA PC AS FAT !!! NOT FAT32 [which is default] !!!!!
Then follow the simple instructions
1. copy all OS Image files to SD card [now formated as FAT system]
2. hard restart Acer n35 device [move knob to the left]
3. Instert the SD Card
4. Hold the power button, and move the hard reset knob to the left
5. aproximatly count 4 sec. and release the power button
6. the screen will say SD DOWNLOAD [not DOWNLOAD IMG] and then after ~10 sec. the Orange bar will appear
7. The device will reboot automatically after it has completed flashing .
cheers
I tried the files, they work , you need to download them, to use eboot 6 first, and then to follow the procedure I also tested rapidshare links provided by coolguy, they seem to work too. I am reposting the links here. I think that if you use this information properly you should be able to get your phone working.
http://rapidshare.com/files/73613168/ace...
http://rapidshare.com/files/73613169/ace...
http://rapidshare.com/files/73613170/N35...
http://rapidshare.com/files/73613172/n35...
http://rapidshare.com/files/73613174/n35...
http://rapidshare.com/files/73613176/n35...
http://rapidshare.com/files/73613177/n35...
I couldn't find a free donwload...yet. I only found a paid download,
http://www.ipaqrepair.co.uk/view_product.php?product=769
I have looked for a manual for your PDA but could not find any what you can try is holding the power button/home then:
If this does not help then here are the contact details of the company just ask them they will tell you the right procedure.
408.432.6200
1.800.733.2237
Goodluck..
Did u try the method i suggested??
i have found the manual hope it helps ya..
Click HERE
hi again,
Got your os image file click HERE and check this post at last you will find all the rapidshare links..
Goodluck..
hi again,
Goodluck..
Please reply i have given you he os file links..
Maybe you have to many files on it. have you tried to erase some datas and some applications? if so, then resesting it may be applied by using a usb cable and a software for reseting it, and a pc is required.
but I recommend to you to let a person who can do this, reseting your pda may cause a fatal damage to your unit if not properly reseted.
hoping your pda will be in good condition after..
please don't rate me badly..^^
Unfortunately it has not worked. As I am a resident of the UK, the phone numbers are not practical. The Uk Company are not helpfull as the model is discontinued
Thanks
The only files on it are the default files, which I believe are corrupted. I can load software, but it will randomly freeze after that or even without loading any programmes
Regards
Yes
I think I need to re-load the osimage file. Can someone tell me where I can get it from
Thanks, but the files will not load. It looks as if I will have to have it repaired.
