Question about Olympus EZ 14-45mm f/3.5-5.6 for SLR
Limited zoom Hi there. I have a 14-45mm zoom. It zooms between 35mm and 45mm but the ring sticks at 35mm & goes no further. Any idea what the problem might be. It works on the camera between these positions. Autofocus seems to work. Lennie
  • 4,889 Answers
See this is a serious problem and i wont try this job myself for all the money on earth. If you damage the lens shutter it is going to cost you much more than the price of the camera believe me! I strongly advice you give it at a service center!
Posted on Feb 14, 2008
    Genius:
  • 3,422 Answers
You mean that the lens are getting stuck right??
If so then follow the below steps for fixing your lens problem:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum cleaner.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. Take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. A lot of people have reported success with this method. HOWEVER, there is some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables.
Fix #7: Try forcing the lens. Many people have also reported success with this method. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include pulling, pushing, rotating or twisting on the lens barrel while hitting the power button. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the lens barrel side that has the largest gap. While doing these, listen for a click that indicates that the lens barrel guide pins have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Goodluck...
Need instruction manual for Olympus Accura Zoom 105
No problem. Just click here. Or cut and paste the address below into your browser.
http://www.olympusamerica.com/files/Accu105R.pdf
Please take a moment to rate my reply.
Sep 16, 2010 | Olympus Accura Zoom 105 35mm Point and...
I need a manual for AF 35-70mm f2.8 D zoom nikkor - no idea how to use this lens.
i was not able to find a manual - this review may help http://www.kenrockwell.com/nikon/3570.htm
The lens consists of
  1. Zoom
  2. Focus
  3. Aperture
  4. Macro
1) Zoom - this is by push pull - so you push the lens out to wide angle 2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended 3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Mar 29, 2010 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Zoom in close for sports pictures
Do you have a zoom lens on your camera? if not, you can get one for it. your lens will say, for example, 70-200mm, or 18-50mm, for sports, you need at least a 200mm or so to get close enough to the action.
Feb 20, 2009 | Nikon N60 35mm SLR Camera
Zoom doesn't work on an Olympus 35mm IS-20 HELP!
Yes, Zoom Drive Assembly gears are broken.
Common problem.
Needs servive
Feb 03, 2009 | Olympus IS-20 DLX QD 35mm SLR Camera
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
What type of lens does the DiMAGE 5 use?
The DiMAGE 5 offers a 7x high power zoom lens, with a focal length of 7.2 - 50.8, which in 35mm equivalent equals 35 - 250mm. A manual zoom ring controls the optical zoom. The DiMAGE 5 has a maximum aperture of f/2.8 - f/3.5.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Olympus EZ 14-45mm f/3.5-5.6 for SLR Logo
149 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
