Question about Panasonic PT-AE700U Multimedia Projector
Replacement of lamp
I am an installer and I got a call from a customer that said that they changed the lamp on the ptae700u projector and now it won't come on can you help?
  • 682 Answers
Please confirm that the customer closed lamp cover firmly because improper actuation of lamp cover safety switch will shut down the lamp.
Posted on Mar 14, 2008
How to replace the lamp for Panasonic projector
If you bought a lamp from eBay then its most likely not a real brand bulb. The PT-AE1000 uses an ET-LAE1000 lamp that should have an Osram, Philips or Matsushita brand bulb. If you do not see PVIP, M or UHP on the bulb then its most likely your problem. Cheap lamps are not worth the money. They fail early and end up costing you more money in the long run. Panasonic Projector Lamp
These folks sell lamps that always work. I would return the eBay lamp and buy one that will work. Their support and customer service are one of the best in the industry.
Aug 11, 2015 | Panasonic PT-AE1000E Projector Lamp...
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
PT DZ13KU NOT WORKING AFTER LAMP REPLACEMENT
I think your best bet will be to contact Panasonic Customer service. But the most common cause for this is that the lamp connections weren't properly re-installed, or there's an interlock switch that is in the wrong position from when you had the lamp(s) out.
Apr 11, 2014 | Panasonic PT-DZ13KU DLP Projector
When I put in the new replacement, the tv won't turn on. All I get is a few short bursts of clicking and then it turns off. I think it is because the ballast is not seating properly, but am unsure...
Definitely lamp is not installed properly if TV was working fine before replacment.
Also check for wright part number on new lamp,or new one is defective.
Aug 15, 2011 | Panasonic TYLA1001 TYLA1001 Projector Lamp
My PTAE700U Panasonic projector has a blue area going down one side of the screen. What wouls cause this and how can I fix? Thanks, Pete
hi,
first check is complaint is with ur projector or the source u ar using. just connect any other input to ur projector and then test. if then also the problem remains, there is some problem in ur projector circuit board or lcd panel. if so u should consult the manufacturer for assistance.
ok
Dec 22, 2010 | Panasonic PT-AE700U Multimedia Projector
Do they make brighter bulbs for the LitePro 580 projector
Nope. You can NOT increase brightness of a projector by installing a brighter lamp. Sorry. The only option is replacing the projector with a brighter model.
Oct 20, 2010 | InFocus Litepro 580 Replacement Projector...
How reset panasonic ptae700u when you change lamp thank you
Go into the menu under "Option" and reset lamp hours to zero
Aug 03, 2010 | Panasonic PT-AE700U Multimedia Projector
Every 15 min or so my tv shuts off and a over temp light starts falshing on the front of my tv and the bulb has just been changed in january.
Hello!
Looks, like one of your temperature sensors has been damaged. May be due to severe overheating by old lamp. Or: the lamp could be improperly installed. Heats up, then connections to ballast fail, lamp quit working. Next possible cause: did you clean air filter? Vacuumed or blow fans with compressed air? Another possibility: If there was not a significant dust accumulation inside of lamp compartment, the ballast board itself can be at fault. In any case, unit might behave the way it does now. Also: have you reset the lamp timer? In projectors, they won't just give you annoying message via "on screen display". It might think, that you never replaced the lamp, just took it out and put back in. You must reset the lamp timer first. The procedure could be in owner's manual or come with OEM replacement lamp. Generics or "bare" lamps might lack that note. Panasonic wants to stay in a business!
Good luck with your project,
thanks,
Alex.
Jun 13, 2010 | Panasonic PT-D5600U DLP Projector
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
Sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Oct 31, 2007 | Sharp Projector lamp Projector Lamp
Panasonic PT-AE700U Multimedia Projector Logo
97 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
