You could buy your self a one for all remote control, then programme in your tv from book supplied with control, and it should fix your problems, the best one for all remotes are kameleon and they are doing very reasonable prices on ebay compared to what i paid for mine. hope this helps
To get your TV off standby mode, you can try the following steps:
Check the power source: Make sure that your TV is properly plugged into a working power outlet or surge protector.
Check the remote control: Press the power button on the remote control. Sometimes, the TV may be in standby mode due to a problem with the remote control. If the remote control is not working, try replacing the batteries or using a different remote.
Check the power button on the TV: If the TV does not turn on with the remote control, try pressing the power button on the TV itself.
Unplug and plug back in: Unplug the TV from the power source for at least 30 seconds and then plug it back in. This can reset the TV and may help to get it out of standby mode.
Check for a timer: Some TVs have a timer function that automatically puts the TV in standby mode after a certain amount of time. Check the TV settings to see if this feature is enabled.
If none of the above steps work, there may be an issue with the TV's hardware or software. In this case, it may be best to contact the manufacturer or a professional repair service for assistance.
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
or
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
or
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
or
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
To get your Hiteker TV out of standby mode, try pressing the power button on the TV or the remote control. If this doesn't work, try unplugging the TV from the power outlet for a few minutes, then plugging it back in and turning it on again. If the TV still remains in standby mode, there may be an issue with the power supply or internal components and it may require servicing by a professional technician.
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
When you turn that TV "off" with the remote it go's into standby mode, that is the way they made it unfortunatly
To actualy make it not have any power going to it you will have to unplug it or plug it into a power strip and use the switch on the power strip.
They use the standby mode to allow the TV to turn on quickly without making you wait.
