Question about Toshiba 32WLT66 32 in. LCD HDTV
Toshiba 32wl66es hello.. I have Toshiba TV 32wl66es.the problem is the screen is on put I cant control.no any information by menu or other bottum. I need your help . thanks
jerryg50
  • 1689 Answers
SOURCE: Toshiba TV - 29 inch - model 2990 XEL
This may be a fault with the firmware (internal software for the uPC), or it may be a failure in the circuit area or chip that generates the fonts and characters for the menu display.
You will have to send the set for factory level service if this is the case. If you give the set to an independent service center, they may have to send the set out on your behalf.
I would be careful to not invest too much money in to servicing a TV of this generation.
Jerry G.
Posted on Jul 12, 2008
SOURCE: Remote Setup Instructions for Non-Toshiba TV
I need a set of instructions to set my TV remote control (Virgin Meadia) to the Samsung top box
Posted on Oct 24, 2008
  • 56 Answers
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Posted on Jan 14, 2009
tlm931
  • 273 Answers
SOURCE: my toshiba big screen tv is shaky and blurry
most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
Posted on Jan 20, 2009
  • 48 Answers
SOURCE: I want to connect my Toshiba Satellite A305-S6863 Laptop to TV
You have to configure yout laptop to output through the s-video (which does not carry sound, so you need to either use the laptop speakers for sound, or the line output (headphone jack) to the TV).
I don't know if all toshibas are the same, but with mine, if I hold Fn (near the windows key) and press F5, it will change the output, do it a few times until you see a picture on the TV, some settings make this your extended desktop, meaning you can drag a window from one screen to another.
Posted on Apr 28, 2009
Testimonial: "Very helpful and well stated information! Thank you."
TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
Feb 24, 2014 | Toshiba Televison & Video
Can i program a toshiba remote control to work on a sylavania tv
Some Toshiba remote controls will not have setup codes to Sylvania. Anyway, check these codes. 0392,0396. For more information, check these links.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Nov 16, 2013 | Toshiba Televison & Video
How to remove messages on the bottom of the screen
Hello!
Try to push "display" button on TV's remote control. If no luck: enter TV's main menu, "setup" paragraph, look for "information banner" or similar. disengage it. Or: turn "captions" off. Could be in a "setup" menu or on remote control, "captions".
Good luck,
Alex.
Dec 26, 2011 | Toshiba Televison & Video
I have a toshiba flat screen 42 inch. i went to change the channel and now all i have is a white screen and no sound
Hello
The tuner card in your TV is not working I thinks. Anyway set the TV to its factory defaults. It will make all the setting to factory levels. If this also didn't helep you, repace the tuner card.
To restore the TV to its factory setting:
[1] Press Menu and open the SETUP menu.
[2] Highlight INSTALLATION and press ENTER. A new set of installation menu will appear.
[3] Open the SYSTEM STATUS menu. Hilight the SYSTEM INFORMATION, and press ENTER.
[4] Press [ => / [5] Enter your PIN code (or 0000 if no PIN code has been set).
OK
Apr 21, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Channel search on toshiba 27afx54 tv without remote control
Hello
There is no MRNU button on the front panel of your Toshiba TV. So it is impossible to tune it manually. You must have its remote control to select MENU options. OK.
Jan 02, 2011 | Toshiba 27AFX54 TV
Help
hello! buy a universal remote control. it can control anything that has a remote. it has a menu button. costs around 10 $
Jun 30, 2010 | Toshiba 20AF41 20" TV
Toshiba 65H81 Displays static, however menu screens fine
Well in this case you may have an issue with your Video Board, if the static showed on the menu, then the issue would have been with your DMD Board, but not in this case.
Jul 27, 2009 | Toshiba Televison & Video
Toshiba TV - 29 inch model 2990 XEL
If don't appear display menu when you press this , your tac switch don't work ( menu switch).
May 13, 2008 | Toshiba 27A44 27" TV
Universal remote control for a toshiba comb tv vcr dvd
How Do I get my Menu button to work for a 26inch Toshiba Lcd flat screen Tv ?
Dec 23, 2007 | Televison & Video
Open Questions:
See all Toshiba 32WLT66 32 in. LCD HDTV Questions
Toshiba 32WLT66 32 in. LCD HDTV Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
