Question about GE JES1851 Microwave Oven
Panasonic dimenion 4/ nna772sbbpq
The microwave seems to work but then after about 25 seconds it stops and the time goes off along with everthing else and when you check the food inside it has not heated it at all can you tell me whats broke  thanks dominic
  • 1,512 Answers
You will have a failed magnatron, rectifier diodes to same, or a power supply fault.
Posted on Feb 14, 2008
  • Graeme Ross
    Graeme Ross Feb 14, 2008
    I strongly recommend that you take it to a repair center, there are dangerous voltages inside a microwave, and not a "safe bet" to attempt to work on it unless you have experience in high voltage circuits. I know this is not a fix,but its the best bet:)
    regards
    Graeme
I need a user manual for a panasonic dimenion 4
Do you have a model number (It will look something like NN-C803) .....if you do, you might find what you need at http://kitchen.manualsonline.com/manuals/mfg/panasonic/panasonic_microwave_oven_product_list.html
Jun 04, 2010 | Panasonic Microwave Ovens
sounds to me like the electronics are off, not the innards. do any of the presets work any differently than the timer? Try the popcorn setting
Feb 28, 2008 | Microwave Ovens
Microwave runs for 3 seconds and stops
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
May 31, 2010 | Panasonic Microwave Ovens
Panasonic 1200 watt microwave oven model:NN-S561BF,year:May 2001.When trying to heat foods the unit runs for 5-10 seconds then stops,I don't sense any heat.Anyone have any common repair tips? as I have...
Wow you must have been a TV repair tech too. Salute!! They have gotten more safisticated but some things never change. The magnetrons are real reliable. If the unit runs for 5 to 10 seconds it sounds like a control issue. The only other possible problem could be a bad HV diode. The new units have the safistication to know when the magnetron is not working and would shut down. Certainly an easy and cheap fix. You seem to have the expertise to explore this. Let me know how it works out or if you need more info. Thanks for using FixYa.
hardrocko
Feb 11, 2010 | Panasonic Microwave Ovens
Microwave turns off by itself after being on for 3 seconds
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Mar 03, 2009 | Panasonic NN-S532 1200 Watts Microwave...
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Jan 04, 2009 | Microwave Ovens
Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Hi there, I have a panasonic microwave which is a few years old now. The problem is that it goes for about 20 secs then stops, the display returns to the time and the light in the microwave goes out....
22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 30, 2008 | Microwave Ovens
GE JES1851 Microwave Oven Logo
100 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
