Reinstalling windows. How Do You reinstall windows? do you need a disk or something? and if i reinstall windows does it wipe out what i have on my computer? Help much appreciated!
  • 152 Answers
You have to have cd or usb to reinstall.... if you reinstall windows it wipes data on the drive in which you are installing windows i.e C:....
Posted on Feb 14, 2008
Toshiba not responding
--Clean the disk space..
--Stop auto starting programs.Click Start > Run and type "msconfig" at the prompt. Click the Startup tab and look at all that junk that loads when you launch your PC.
--Clean up the registry.
--Upgrade RAM.
--Reinstall Windows. If the above tricks haven't helped, it may be time to wipe the slate clean and start again, reformatting your hard drive, reinstalling your applications, and restoring your data files from a backup.
--Upgrade your hard drive. This is a more complicated solution, but if you're reinstalling Windows (per the prior tip) you might consider upgrading to a bigger and possibly faster hard drive, too.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | Toshiba Computers & Internet
Reinstalling windows xp
You'll need a operating system disk that is the same as what is on your system (Xp Home, XP Professional). Put the disk into the CD Drive and when the system comes up Select Install. Hit F8 to accept the license agreement. Afterwards the system will look for already installed versions of Windows. If you want to keep your data, documents, music, pictures, videos and programs select to do a Repair of the windows system it found. If you want to wipe out everything just don't select the repair option.
Mar 30, 2012 | ASUS Eee PC 1001PX-EU27-WT 10.1-Inch...
I need to reset my acer aspire one to factory settings, i have backed up everything on an external hard drive so i don't care about losing things off the netbook. It is an A0751h. It has no disk drive nor...
In order to "reset" a computer you will need to reinstall Windows XP. Most PC makers no longer give CD copy of windows with their products, and so they'll usually put a copy of it on your hard drive.
You can find this by going to
C:\Windows\i386\Winnt32.exe
Selecting this .exe will lead you through a step by step guide to wiping and ultimately reinstalling windows on the machine.
Sometimes the i386 folder is in the root, depending on the Brand.
Apr 07, 2011 | Acer Aspire One PC Notebook
Want to wipe everything out back to factory
If you have a restore CD then you can reinstall Windows.
If you have a Windows installation CD then you can use this to reinstall Windows.
Reinstalling Windows will wipe your data from the hard disk.
Dec 10, 2010 | Toshiba Satellite A205-S5804 PC Notebook
How do i reset my toshiba m45-5165 satellite laptop back to factory settings without a recovery disk
if you have it saved on part of your drive i belive its f10 on the boot up failing that use a o/s :ie xp vista windows 7 disk and re-install it.
Oct 06, 2010 | Computers & Internet
Blue ecreen error, system shuts down
Hi.
Blue screen means that an exception handling memory or a different computer resource has ocurred.
Blue screen error often occurrs when the sytem is corrupt.
Usually it is possible to fix the problem reinstalling Windows operative system.
Before reinstalling Windows you can try starting the system in safe mode (try F8 on startup). If system starts in safe mode, do a system restore to a recent date before having the problem.
Windows can be reinstalled using either factory recovery disk or a generic Windows setup disk in conjunction with a valid Microsoft licence number.
In case reinstalling Windows does not fix the problem, even if there are more hardware faults that can cause the problem, the first culprit is usually RAM memory.
Try reinstalling the system first.
Aug 08, 2010 | Acer Computers & Internet
I need to reformat my friends acer 3000 its running windows exp but he does not have the disk or the coins to buy 1 also is there a way i can wipe it clean without reforammting keeping xp on there so i...
You can install a software like TuneXP which works out perfectly cleaning your PC's registry, useless files, startup programs, reinstates icons on desktop and lot more. You dont have to take the burden of reinstalling Windows XP again on your laptop after formating.
Sep 20, 2009 | Acer Aspire 3000 Notebook
Need to reinstall window xp how and where do i start
Do it this way, go into bios and check "boot from disk" put your disk with Operating system in the drive, and restart, you will get some choices here you click on install, then it will ask you if you want to format, do a quick format, NTFS. it will format "wipe out " the old stuff, and begin reinstalling the new operating, dont try and save anything as you will just be dragging the ols problems along with you. Get your motherboard disks ready in case it asks for a raid driver or some Motherboard driver. and that is it , in around 45 minutes you will be done, you will need the serial numbers from your copy of windows. Have fun, when done just downlosd the updates, have fun Gym
Dec 20, 2008 | Dell Dimension 8400 PC Desktop
Will reinstalling windows vista help me in starting my computer over
yes if you format it first you can go to www.formatdisk.com and get a format disk you will have to have a flopppy disk to do so
this program wil be all in dos commands, so if you have any problems please fill free to email me at douglahudso@yahoo.com
thanks
hope this works for you
Aug 21, 2008 | Computers & Internet
System recovery
Solution :
Request Backup Disks and Manually Reinstall :
If other methods for reinstalling your operating system have failed, the only option is to reinstall from the installation media.
Request Backup Disk by clicking the link below :
https://support.dell.com/support/topics/global.aspx/support/dellcare/en/backupcd_form
After Seaching a lot on google finally i got the link ,which willb be very helpfull to you
link :
If you need any further assistance just reply me at fixya or contact me at my email id
johny_inmexico@yahoo.co.in
Was this solution helpful? Show your Appreciation by rating it:...............THANKS
May 08, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
426 people viewed this question
Alun Cox
David Payne
David Payne
