Question about Dacor DCM24SS Convection Microwave Oven
Dacor Microwave dcm24s
Push easy minute and the blower starts but the tray does not turn and it does not heat the food. This is an intermittant problem but is getting worse.
  • Dacor Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 15, 2008
Dacor Microwave DCM24S cooling fan continues to run
follow this steps and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#9#ixzz2aNH65mG4
Jul 27, 2013 | Dacor DCM24SS Convection Microwave Oven
Dacor DCM24S microwave not working--not heating and table not rotating
The bottom door switch or its mount is bad.
See the service manual here and a help file on door switches here.
Nov 23, 2012 | Dacor Microwave Ovens
Can I get an electrical schematic for the Dacor DCM24S. Thank you. AE.
We have the full service manual for this model and have uploaded it for you here.
You can order parts (by part number only) from the Pros here.
Let us know if we can help further.
We're
Jan 15, 2011 | Dacor DCM24 Convection/Microwave Oven
I opened the door on our Dacor microwave after heating food and the interior light, which was on for about a second, blinked off. The light will no longer come on when the door is open and the microwave...
On the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
Oct 21, 2010 | Dacor DMT2420SS Microwave Oven
Dacor DMT2420S Microwave has light and touch pad fully functional but when you push start, the clock counts down normally but no sound of the oven running nor does the turntable turn. Food does not heat....
Simple fix.
You need to replace the bottom door switch, or repair its loose or broken mount.
See this help file on door switches, and refer to the service manual here for disassembly help.
You can find part numbers here and order Dacor parts (by part number only) here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Aug 22, 2010 | Dacor DMT2420SS Microwave Oven
Turntable not turning
you should be able to repair this your self the turntable motor is fairly easy to get to.it does sound as though your motor has gone bad.
Jan 31, 2010 | Dacor DCM24 Convection/Microwave Oven
Dacor microwave model DCM24s broken door latches
Many times restaurant supply houses can have what you are looking for in terms of hinges. However, when the hinges, seals, megatron tubes go....generally its time to go shopping for a new unit!
Nov 09, 2009 | Dacor DCM24SS Convection Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
141 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
