Question about Electronics - Others
Copy data of 40 pin ide flash module
Dear sir
i have transcend 40 pin ide flash module.
there is data in it. i want to copy the to cd rom. but the problem it doesnt show the files in windows explorer. please give me the solution
thanks
If its accesible than ur problem might be easy...check if u putt ur files hidden by hitting ctrl + a...if a msg apper thats it..go folder option and chek the show hidden files..if a msg dont appear try recovery prorames or try file transfer wizar
Posted on Feb 15, 2008
MY DELL GX270 IS NOT SUPPORTIN THE IDE IN HIS BIOS. I HAVE TRIED MY ALL TRICK BUT I CAN'T SOLVE IT PLZ TELL ME THE SOLUTION. WHEN WE ENTERED THE WINDOWS CD IN THE CD ROM. IT INSTALL THE WINDOW. BU
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE
The leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty. Any bad or faulty power or data lead or connection can cause a computer not boot up.
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Feb 08, 2013 | Dell OptiPlex GX270 PC Desktop
In my computer CD drive is not listed .I changed the jumpers from master to slave and slave to master. CD drive has got power it opens and close but not reading CD/DVD even it is not listed.model t3304.my...
Make sure the data cable is fully connected to the motherboard and the CD-Rom drive. If this is an IDE drive, make sure the jumper choice matches the position on the cable (the 40 pin wide ribbon cable that supports two drives). It also needs to be correctly oriented in the unit - the red stripe on the edge marks the side that goes to pin 1. Only use slave if there are two drives connected to the cable and the CD-rom is on the slave connection. (Note the connectors are black (motherboard), blue (master) and grey (slave) on a standard IDE ribbon. Newer IDE drives have a Cable Select option that you can leave the jumper set to and avoid issues of getting the connections wrong.) If it uses a SATA cable, the jumper should stay as Master (IIRC). If available, try a different connection on the motherboard for the data cable. (Some modern motherboards only have one IDE connector.) If you have any sort of IDE to SATA converter in use, try a direct connection in case the converter is damaged. SATA cables sometimes are designed to latch into connector on the drive so make sure it is fully seated.
Replace the cable if it still isn't connecting. Then check the status of the drivers. In Windows, use the Control Panel and go to the Device Manager. Look to see if the unit is listed with a red X or yellow exclamation point in a triangle. Try to update the driver.
If the above suggestions do not help, you should consider a new optical drive.
I hope this helps.
(I have frequently seen a non-responsive drive due to a loose data cable.)
Nov 22, 2010 | E-Machines emachines (emachinees) CD-ROM...
Not deteck hdd & cdrom
Power down you're system and remove the power cable from the PS.
Open you're case. First clear the cmos jumper. See bottom of page 14 in manual. The GA-8VM533M-RZ motherboard was made Jan-1-2004. It is very likely that the cmos battery needs to be replaced. Average life span is 5 years or less. Pull the cmos battery and check its voltage with a voltmeter, it should read no less than 2.7volts DC.
I'm guessing it’s the bios that’s not seeing the CD-ROM drive and the hdd? Suggest you check both the data cables and their power cables.
Since the GA-8VM533M-RZ motherboard only supports ATA IDE hdd's, check the drives jumper. (It should be jumpered as a Master) and so should the jumper on the back of the cd-rom drive. See the link provided; http://www.easeus.com/resource/install-ide-hard-drive.htm
The link above helps but you're hdd may be different. See the sticker on
you're hdd for the correct jumper setting.
If you are using a single data cable to connect both cd-rom and hdd to the motherboard don't. Use an 80-pin data cable for the hard disk drive. You can use a 40-pin data cable for the cd-rom but if you have a spare
80-pin data cable connect the cd-rom drive to it.
Connect the hdd to IDE1 and connect the cd-rom to IDE2. See motherboard layout in the manual page 5. Need the manual? Download it from Gigabyte; http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1766
To view the manual you will need to download and install Adobe reader;
http://www.adobe.com/products/reader/
Re-connect the power cable to the PS. You can leave the case opened for now. Power on the system and press the Delete key every 2 seconds until the bios menu opens. (Make sure the time and date are set current). See page 19. Than turn to page 23. Make the settings as follows;
First Boot Device [Floppy] - (if one is connected)
Second Boot Device [CD-ROM
Third Boot device [HHD-0]
Password Check [Not needed]
CPU Hyper-Threading [Enabled]
Check all settings while in the bios, save and exit. The system will auto re-boot. If after replacing the bios battery (If needed), and the bios still
does not see either drive than the problem is either the bios or the motherboard's controller. The bios can be flashed but the MB controller can not be repaired.
Cheers'
Mike
Feb 15, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
I have asrock prescott 800 ddr400 fsb800 motherboard. i bought a new dvdrw that is sata. is this dvdrw compatible with the mother board? where to connect?
Sorry but the motherboard Asrock 845GV (P4I45GV) doesn't have a SATA controller and there for does not have the ability to connect a SATA CD/DVD-ROM drive to the MB. However you can buy a serial ATA IDE to SATA converter which will allow you to connect you're SATA CD/DVD-ROM drive into an opened IDE port. Provided is a link to you're motherboard;
http://www.asrock.com/mb/overview.asp?Model=P4i45GV%20R5.0 Next, is a link for the SATA convertor;
http://www.startech.com/item/IDE2SAT25-40-Pin-Female-IDE-to-SATA-Adapter-Converter.aspx
Cheers'
Mike
Jan 30, 2010 | Asrock 845GV (P4I45GV) Motherboard
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
I have pen drive Transcend 4 GB which becomes Write protected and can?t be formated.When I plug it on, it shows Removable Disk in my computer and it contained autorun.inf Folder having 2 files which could...
Hello sir,
You can recover by doing the following:
go to transcend website and download this software;
(http://www.transcendusa.com/products/online_recovery.asp) and then you have to select repair and save data..
Regards
Devesh Golani
devgolani@gmail.com
Mar 17, 2009 | Transcend (589307) Media
What type of CD-ROM should I use for ASUS P5QL-E Board
As the others have said, your MB has an 40-pin IDE connector just to the right of the SATA connectors. It is at a 90 degree angle to the SATA connectors and parallel to the RAM slots.
It is shown on Page 2-26 of the manual. (Available at http://support.asus.com/ )
Remember there is a pin missing so that the cable cannot be inserted backwards.
Dec 10, 2008 | Computers & Internet
Motherboard problem
Hi Conor, every SATA drive is a master drive. With that in mind you're SATA must have windows installed on it. Please disconnect the data cable & power cable's from the IDE drives.
(Do not reconnect either IDE untill you have finished).
Install windows on the SATA drive. Install all the needed drivers, than update windows. When finished Check the pin setting on the IDE drives. Set one as the "master with a slave" & the other as the slave. Than you can add both into the system. If you had windows on one of the IDE's just delete the root files on that drive so it does not conflict with the new windows on the SATA drive. Go in the bios make sure you have the SATA drive as the boot drive & not either of the IDE drives. If the system still shuts down after all this, try replacing the data cable for the IDE drives (Both should be on the same data cable). Swap the power connector from the CD-ROM drive to the IDE.
Next, if you're system still shuts down after adding either of the IDE drives, than swap the ports. Connect the CD-ROM to the primary IDE port on the board & the IDE hard drive to the IDE slave port. (This is for testing only). Double check all power connections from the power supply to the motherboard. Leave the case opened. Look at the board when booted. Watch for the the case LED's lighting up & flashing cr-rom's LED flashes, look at the CPU fan. Make sure all fan's are running & listen for the drives running.
Let me know if anything changed or not. Post any thing odd or if any thing did or didn't work & I'll go from there. Everything is a test & error soulation. One change at a time.
Mike
Jun 27, 2008 | Gigabyte Motherboard, GeForce 7100, Core 2...
Transcend t sonic 610 2 gb player is not getting format
when you purchased the t sonic mp3 player 610 box pack at that time or in that box one CD is there. put that CD in CD ROM and install recovery. then in recovery or where the recovery is install go there and select firmware update, when we update the firmware virsion at that time the data will be loss.during the update don't disconnect the drive.
Apr 21, 2008 | Transcend T.sonic 610 MP3 Player
Electronics - Others Logo
122 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
