Question about Technics SL-1210 Turntable
Problem connected my tecnics sl 1210mk5's with serato scratch, all i hear is a constant hum. The mixer works fine cause the kaos effects come through fine. first time ever using these(brand new)
  • 515 Answers
Make sure your ground wire is connected. I know Serato does not work properly if your ground wire is connected.
Also, make sure your running the connection from the Line Out of the Serato box into the LINE IN on your mixer. You can use the Phono Input also, but I generally tell people to use the line input to avoid any issues. Regardless of which input you use, make sure that your Serato software is either set to LINE or PHONO, otherwise it wont run properly.
- DJPROLAB
Posted on Feb 24, 2008
I'm using the serato dj software program.I had my turntables about 5 years.Currently I'm not receiving a good signal from one of my tables.I replaced the phono cords myself but still not a good signal.I...
You check it by trying a regular vinyl record to see if it is the cartridge. Make sure you have the input on phono for vinyl and on aux if you are using serrato. If the turntables are older try cleaning the contacts on the tone arm where the cartridge goes. make sure it is grounded properly also. Try plugging the turntable that is not working in where the working one is to check the channel on the mixer.
Mar 17, 2011 | Technics SL-1210MK5 Turntable
HOW DO I CONNECT A KAOSS PAD MINI TO MY PIONEER DJM 500 MIXER
Try running it in your FX loop ( out of the mixer into the Kaos, out of the kaos back into the mixxer or out of the mixer into the kaos and out of the kaos into your amp.
Jul 08, 2009 | Korg Mini Kp Kaoss Pad
One cdj and one turntable
This is possible, by connecting your turntable to the Line Input on the serato box. Then just connect both to your LINE INPUT on your mixer, and set the controls on your Serato Software to LINE INPUT - NOT Phono.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jan 18, 2009 | Technics SL-1210 Turntable
Song playing backward but table going foward with serato.
hi... swap the left and right rca cable.the one who said it works good on the deck but on the screen goes back ward....see what hapen..u
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
Playing songs backwards wit serato scrach live
I got it partially fixed. The black wire from the tone arm was broken so that been solder back on place nd the rca also the song is playing foward on channel 1 only, thats a start! New problem accuring now! Can't use that table to scarch now caus every time i do so the song goes foward only??? No back and forth in the sound??? I'll get a new tone arm and it should get everything better!
I have a Stanton T.80 and Vestax VMC-185XL mixer. I recently bought Rane Serato Scratch Live which requires the turntables to be grounded through the mixer...however, the turntable doesnt have a ground...
Hi gium
Sounds like we have reached that point where progressive crossover in technologies means that the usual cautions of earth continuity for the tone arm when using a phono preamp has gone the same way as phono preamps on home theatre.
Have you tried switching to the line level and set the mixer up for that level also. That may reduce any gain induced hum. However it sounds like an earth loop problem, where both decks will need to be earthed in the mixer. Check also that all the gear is running of the same power point. Different mains phases are sometimes available near each other, having any gear (power amps also) on a different phase will cause an earth loop problem.
Is the hum all the time independent of the volume levels, or change with levels adjustments and not at all when turned right down. Let me if changing to line levels helps. We can try some more things, like connecting a temp hookup wire earth to the RCA earth to mixer chassis. Cheers
regards
robotek
Oct 04, 2008 | Audio Players & Recorders
Setting up TTM 57SL, All I hear is control CD
This may seem too simple, but have you tried flipping through your channels on your mixer, or try connecting the wires differently.
Jul 31, 2008 | Rane Serato Scratch Live Computer DJ...
Technics SL-1210 Turntable Logo
210 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
