Question about Dishwashers
Hotpoint dishwasher I need to change waste pipe on my hotpoint dishwasher. I was given this dishwasher by a friend and it works well but I cant connect the waste pipe to the bit under the sink as the rubber connection on the end is missing. I bought a new waste pipe but not sure how to connect
  • 55 Answers
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Posted on Feb 15, 2008
How do I change the waste pipe on a dishwasher dw600
follow the pipe iced the machiene and there is a sprung clip like a jubilee clip holding it on ..... you'll need a pair of pliers to squeeze it together
Sep 20, 2014 | Beko Dishwashers
Hotpoint fdw85 does not drain
sounds like the pump is not working
Jun 11, 2017 | Dishwashers
Hotpoint LFT 114 dishwasher......why is it suddenly not getting any water? the pipe connections seem fine and it's worked for years!
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 19, 2010 | Hotpoint Dishwashers
How do i change the waste pipe on a Siemens SE25235 GB dishwashe?
yes. the side panel needs removing to get access to the fill/water matrix. to do this, you need to remove 2 torx 15 sized screws underneath the white seal of the side panel. make sure you have unplugged the dishwasher and disconnected its water supply. once you have access to the water matrix, place a towel or similar absorbant material underneath where all the pipes connect to the matrix (near the back) to prevent any spillages. the waste pipe is the same colour and texture right up to the connection on the matrix and is (i believe) the furthest from the door of the dishwasher. disconnecting the hose shouldn't be too difficult.
Jan 06, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
Hotpoint dishwasher fdw60
the fault wasn't with the machine. we got new waste pipes put in and the conection for the dishwasher hose didn't have the hole for the water to release. thank you for your help
Jul 15, 2008 | Hotpoint Dishwashers
The waste pipe on my hotpoint dishwasher is connected to a spigot. I now want to buy a Bosch replacement but all models have a waste pipe which is too small in diameter to fit the existing spigot. A...
Do you have a garbage disposal? It is usually easier to drain through the garbage disposal. There is a fitting for this on all disposals. Be sure to remove the knock out plug first.
Jul 04, 2008 | Dishwashers
Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Fault with Hotpoint BCI45 Dishwasher
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Sep 27, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Dishwasher
you ..dont need to get into the back.With the bottom front panel off,disconnect the waste pipe frm the pump on the right and pull it through from its other end.
Sep 17, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
329 people viewed this question
Top Dishwashers Experts
