Question about Dell A920 InkJet Printer
Dell A920 Printing Problem
Have changed the black ink cartridge twice but still only prints in colour & a letter in black prints out in blank. Does anyone have any ideas?
  • Alasdair53 Feb 17, 2008
    Many thanks . Both replacement cartridges faulty hence the problem.
  • Anonymous Mar 05, 2008
    Cleaned print heads. Cleaned contacts. tried printing heavy black graphics to flush cartridge but still very poor quality (if any) black print out.
    Sniper:
  • 60 Answers
You should check:
1. Did you insert correct the cartridge in the holder?
2. Check if the contacts are clean in the cartridge holder, maybe something is ther and the needle-type contacts from the printer does not push right on the cartridge contacts.
Posted on Feb 15, 2008
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
I changed theblack ink cartridge twice and it still won't print in black, colours are printing but no black
Ink level data is stored in a chip of the cartridge. Once the cartridge is empty, ink low message will appear eventhough you refill the cartridge. You need to deactivate ink level detection function to continue printing in case of usage of refill ink .
Search google on how to change ink level detection
Chris Thrash
B52Computers
Jan 10, 2011 | Epson Office Equipment & Supplies
My printer has been printing just fine until today. It still "acts" as though it is printing, but a blank page comes out. I have replaces both black and color cartridges and have shut down the...
Have you tried running cleaning the nozzles using the software? Here is a link on how to do it:
http://support.dell.com/support/edocs/systems/A920/a920en1.pdf
just checking that you also removed any "tape" that might have been on the ink cartridges prior to installing them?
Oct 27, 2010 | Dell A920 InkJet Printer
Why doesn't my A920 injet print colors properly--green comes out pink, and I still have half the ink left in my color cartridge.
1) Could be your printer settings, check out your printer preferences to make sure your not printing a negative or make sure you colour corrections is enabled.
2) If the colour cartridge is a 3 in 1, just one of the colours may have run out. Giving a distorted picture. That means a new cartridge. The best way to check that is to go to your printer tool box and print out a test sheet. There should be 3 colours (Magenta, Yellow and Blue) and Black. If one's missing, the cartridge is out one colour.
Jul 21, 2010 | Dell 924 All-in-One InkJet Printer
My Dell A920 printer will not print the color blue. I've replaced the ink, 2 times. Changed the quality of print to "Best" and still get only the reds & yellows... Any ideas?
hi there !
-try the old cartridge if it will print the correct colour; the problem is the cartridge; otherwise it is the printer.
cheers !
Oct 24, 2009 | Dell A920 InkJet Printer
I've installed a new coloured catridge but printer
did u remove the peel off cover that protects the contacts or the print head on the new cartridge?
Feb 17, 2009 | Dell A920 InkJet Printer
A920 printer will not print in color & the cartridge is OK
is there any more colour ink inside? if there is ink inside you just have to open your printers properties dialog and look for a color option that uses black only. 2. see if the colors are blocked
Feb 07, 2009 | Dell A920 InkJet Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Unable to print using black printer cartridge
Well, Yeah mine did the same thing!!
And I got soooo fusy! and etc. But yeah okay go to the manul script and look for the ink Number then once you find the ink number go and buy the ink that has the same number of ink as yours!
Then,
Once you get home replace it with the others.
BUY THE BLACK INK! not the TRI-COLOR!
Sep 25, 2006 | Dell A920 InkJet Printer
Dell A920 InkJet Printer Logo
166 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
