Question about Canon BubleJet i965 InkJet Printer
I965 print problem
I have a printer from canon i965, I have changed all the inks but the printer can not recognised the ink and does not print the test page at all.
Please help. I have done all the maintenance test.
  • den28 Aug 31, 2008
    I have put a new canon 965i black cartridge in my machine and now none of the colours work the sheets are coming out blank- this is a canon cartrige not a cheap one i have run through every option to solve this apart from throw the thing out the window
    please helpppppp
    Sniper:
  • 60 Answers
If you used the right cartridges (here you can see them http://www.mediatec.ro/mt_main.php?consumabile-cartuse-toner-inkjet&st=1&marca=Canon&model=i%20965&tip=inkjet - first are compatibles and second the genuine Canin ones) the printer should start. Did the printer worked fine until previous cartriges runned out?
Posted on Feb 15, 2008
Why is the orange light is flashing ?
Replace the applicable ink cartridge,
or press the Stop button for 5 sec. or
longer to continue printing without
replacing the ink cartridge(s).
When the error is cleared by
pressing the Stop button, the
function to detect the remaining ink
amount is disabled
May 12, 2014 | Canon BubleJet i965 InkJet Printer
Canon i965 printer
First ensure it is not a cartridge problem, try a replacement.
It does not look like a print head problem, it can be a driver problem or a logic fault in the printer.
Sep 05, 2008 | Canon BubleJet i965 InkJet Printer
Canon i965. light tones leaning to magenta. printer 6 years old
Because of the way they're designed, older Canon printers can sometimes get dirty print heads which can cause some ink colors not to come out properly or at all. This can cause light printing or a tendency to a certain color, like what you're describing.
The best thing to do would be to go into the Printer Settings (by opening Control Panel -> Printers and Faxes) and right-click on the i965 to select 'Properties'.
Somewhere in that menu will be an option to run a Print Head Cleaning. Find that and allow it to run, and then print a test page to see if the colors have gotten back toward normal.
If it's still printing strangely, you might want to try to find a new print head (check www.canon.com to see if they still support the i965 model). If you can't find a replacement head for the i965, it might be time to buy a new printer, since it will probably cost more to have yours looked at and repaired than it would to simply replace it. Sad, but true!
Hope this is helpful!
May 08, 2011 | Canon BubleJet i965 InkJet Printer
Yellow ink isnt printing even after deep clean and test page print
Maybe the ink inside the catridge already low or empty, sometimes each color ink will empty at different time, depend on usage. Fill only the yellow ink and try to print again.
Hope this help and RATE please !
Jan 18, 2011 | Canon BubleJet i965 InkJet Printer
Canon I965 waste tank almost full - how do I clean/empty or clear
You will have to get it replaced by a Canon agent.
Phone Canon for nearest agent
Just had mine done cost £50.00 +VAT
The codes on line to reset counters will not solve the problem and eventualy ink will leak from the printer.
Feb 24, 2010 | Canon BubleJet i965 InkJet Printer
Print head failure signal
Error 5 is an ink cartridge error. Cleaning the print head and electrical contacts on the cartridge does not fix this error. You need to get a new cartridge to fix the problem.
Feb 09, 2010 | Canon BubleJet i965 InkJet Printer
Printer is not printing after putting in new ink
hi from brisbane !!
your Canon printer is detecting low ink in the cartridge and stops the feed of ink .
i have had the same problem and have only refill the cartridge and its away again .
the cartridges have a few contacts on the back and sometimes by applying a magnent to those contacts , it erases the memory and start printing again .
try that and let me know how you go .
Sep 30, 2009 | Canon BubleJet i965 InkJet Printer
Canon i965 flashing amber light
Hi nnub1,
You might try unplugging the printer from electrical source and try unplugging your data cable from the computer. Shut down your computer and disconnect the data cable. Start your computer and then reconnect the data cable. This is assuming you have a usb data connector.
What you want to do is to try to get the printer back to its default settings. The amber light flashing is trying to tell you something. You should also unload any pending documents to try to get the printer back to its default state, but disconnecting data cables and or power connection is going to be required.
Respectfully,
Terry
Jun 10, 2008 | Canon BubleJet i965 InkJet Printer
Canon i965 error message 'The used ink tank is full.'
I have same problem. Have tried both solutions but neither have worked. Anyone have any other ideas?
May 10, 2008 | Canon BubleJet i965 InkJet Printer
Canon BubleJet i965 InkJet Printer Logo
176 people viewed this question
old marine
old marine
