Question about Toshiba Satellite A205-S4607 Notebook PC
Help me I dont know what iv done, but my disc drive, usb and sd card wont even recognise on my computer. Can anyone help with this iv had a computer guy come out and he couldn't fix it. my laptop is actually a toshiba satellite a200
  • 72 Answers
Repair the windows installation by using the windows installer cd or the cd that came with your laptop it has restore function,just run the cd then after the repair, boot your PC and if it ask for the software drivers reinstall it. I did this with my laptop with the same model as yours and it work fine. Im now using it until then without problems
Posted on Feb 18, 2008
  • 118 Answers
Restore your lap top to previous check point, you can do this by pressing F8 key while booting and select the safe mode when asked restore the system to a previous check point.
Good Luck
Posted on Feb 16, 2008
  • 60 Answers
Has anything major happened recently? Has windows been reinstalled or did you notice any unusual behavour before you lost the use of them?
Posted on Feb 15, 2008
My girl took pics of wedding Saturday and viewed pics earlier today. When she went to look at them again, a message " Disc in Drive E is not formatted. Do you want to format disc now?" Of...
do not format -- you will lose the pictures
instead go to another computer that supports SD memory and CDRW. insert into that computer and then take all the PICS, save into that computer. now take a blank CD and take the saved PICs and burn into CD.
Also, to ensure you dont lose these pictures (PICs) you may want to buy a 4G or 8G USB thumb drive (about $10-$15 or less) -- drag and drop all the PICs (saved on that computer) into the USB thumb drive. Now you have on CD and USB drive.
hope this helps
Nov 14, 2010 | SanDisk 2GB microSD Memory Card
Not knowing how to insert into hard drive.
You need a USB to Flash card adapter, you push the little card into the slot, and if it is a mini card, it has to go into another card "Carrier" that plugs into another adapter, that then plugs into the PC, either through the USB adapter or a slot in PC, anyway, when you insert it, automatically, a driver will be installed, it is "Built into" Windows, now after it has done so. you can simply use it as a "Drive", meaning you can Copy, Cut, Paste.
Mar 01, 2010 | SanDisk 2GB microSD Memory Card
SD card wont load on my t-mobile G1
try to go to a free check up cellphone repair...
check if your sd card slot is working fine...
if not you know now what is the problem...
but before it...try to fix it by yourself...just make some little adjustments...
Feb 11, 2010 | Kingston 4GB Secure Digital High Capacity...
My gps device wont load.
if you mean you moved everything from the flash drive to the sd card, plug in your 3100 to your computer via the usb cord and also plug in the home charger if you have one, or make sure the battery is fully charged by plugging it in fo a few hours.
put your sd card in your card reader, open the sd card drive in your computer and copy (do not move them, use the copy option) then copy the files in to your flash drive for your 3100.
it will take awhile to transfer those files, because its like 1.6 gb.
after its done transferring the files, reboot the 3100. if that fails, let me know by replying to this post so i can continue to help you.
bill
Feb 10, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
My computer won't recognize my cruzer micro 8gb stick. I don't want to reformat, because I have at least 1000 pictures, plus Quickbooks, Legacy and other data on it. Anyone have any ideas?
some older pcs wont recognise sticks and sd cards larger than 4gb. it will probabaly be down to the version and service pack of windows you are using.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Ds turns on with R4 Card, but screen is dull and it wont work
sounds like the system on r4 card is missing,if u have ur micro sd games stored on ur pc,add the system files to card again .this should solve the problem,good luck
Jul 02, 2009 | Nintendo DS Lite Console
Games wont load
Same exact problem happened to mine. I ended up modifying it. It is actually easier than it seems
http://www.youtube.com/watch?v=K7RZgFVwE_I&feature=related
May 24, 2009 | Sony PlayStation 2 8MB Memory Card - Black
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Toshiba Satellite A205-S4607 Notebook PC Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
