Question about HP Color Laserjet 3550 Printer
SLOW PRINTING HI , WE HAVE A PRINTER ON LAN AND DUE TO SOME PROBLEMS IT WAS MOVED TO ANOTHE FLOOR AND WE HAVE NOW MOVED IT BACK.THE PROBLEM IS THAT IT HAS STARTED PRINTING VERY SLOWLY .takes almost 48 seconds for the first sheet and another 5/6 sec for next pages can u help pls bindiya
  • tfairs Feb 18, 2008
    Thanks for your response but can not find the Quality under properties...
    Sniper:
  • 60 Answers
Look in options of the printer (Properties) and put quality on FAST or DRAFT
Posted on Feb 15, 2008
  • Iuliu Ciupe-Vaida
    Iuliu Ciupe-Vaida Feb 18, 2008
    Click on START - Control Pannel - Printers and faxes, there you find the printer, right-click on it and choose "Properties". On that window look under Advanced, after clicking it, it should open a multitab window where quality (or density) must appear.
I had the Brother mfc 490 CW connected to a lan network and it was working OK. Just two days ago I unplugged the printer and moved it to another spot in the same room connected to the same lan. When I...
Hello!
"No Station ID" means that your printer is in the mode "Transferring faxes to another fax
machine"
Brother has a Solutions Center.
I add a link to this center, hope it will help you resolve this problem asap.
United States Brother Solutions Center
May 30, 2017 | Brother MFC 490cw Color Inkjet...
Paper jam
Hi Good day!! Follow this method to remove your paper jam:
1. Check to make sure that the power cord is securely plugged into an active wall outlet if your printer is not turning on.
2. Make sure that the USB cable connecting your computer to your printer is securely connected if your printer powers on but will not perform a print job.
3. Remove a paper jam if the "Check Paper" light on the front of the printer is blinking. To do this, first turn off the printer and unplug the power cord from the printer. Open the front cartridge door and locate the jammed paper. Gently pull the jammed paper toward you. Plug the printer back in and turn it back on.
4. Connect your printer to a different USB port on your computer if you are experiencing slow printing. The slowness could be due to a connection problem with your computer's USB port. After you've switched the port, try your print job again.
5. Make sure that a phone line is securely connected from a phone jack to your printer if you are having trouble sending or receiving faxes.
6. Clean the scanner surface if your scans are blurry or have vertical white or black lines. To do this, spray the a soft, lint-free cloth with a mild glass cleaner. Wipe the scanner glass with the cloth and then dry it with another clean lint-free cloth.
7. Hard reset the printer if you are having trouble solving your problem. Turn the printer off and remove the power cord from the wall outlet. Wait at least 15 seconds and plug the cord back in. Power the printer on and try your job again.
8. Restart your computer if you can't solve your printing or scanning job. Sometimes restarting the computer can solve an unseen problem.
Don't forget to vote thanks!!!
Oct 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Jul 29, 2009 | Canon Pixma MP480 All-In-One InkJet...
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
Relocating my xerox doculor 240 to another location.
As long as you keep it level there is no problem moving it. You can run it up ramps onto a truck. Just be sure you secure it well, that machine is top heavy and wants to tip.
Other than that, if you are loading it into t a truck. make sure you place a blanket or something over it and place the paper trays toward the wall so they dont fly open in transport. Its not that difficult to move and I know, Xerox is a rip off when it comes to moving a machine. Just take care, once moved just turn it on, If there are any problems let me know,
Mar 09, 2009 | Xerox DocuColor 240 All-In-One Laser...
Hp 1350 all-in one psc
your paper feed problem may be due to the feed rollers or due to the fact the mecanism that raise the paper doesn't function properly. Normally if you clean the rollers that should work
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
Printer too slow
Sounds like you might have the wrong, or old drivers loaded.
Go to the HP site and download and install the latest drivers for your printer.
Aug 28, 2008 | HP PhotoSmart 7760 InkJet Printer
Wont print
reconnect the way you had it see if it comes back, power it off then back on.
is this have a wired lan connection or wireless?
Dec 13, 2007 | Brother HL-2070N Laser Printer
126 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
