Question about Kenmore 57029 Side by Side Refrigerator
Light switch on a older kenmore refrigerator, how to replace
The light switch in my fridge is out of order. How do I replace the light switch?
    Scholar:
  • 90 Answers
Most light switches snap in place. If there is no apparent screw and the switch seems to have an adequate lip all around it, use a putty knife or butter knife push under that lip at one of the shorter sides and gently try to pry it up. It should pop out. the two wires are usually attached by spade connectors that just pull off. Doesn't matter which wire goes on each. Sears should be able to get a new one. But before you go that far be sure the bulb is not burnt out first. You should also take the switch with you to sears or have a friend test the switch to be sure it is truly bad..
Posted on Feb 15, 2008
Kenmore ref model 795.73266303. After power outage fridge won't turn on. Lights inside work but the digital thermostat is off.
Check the parts list at the link below to see if a circuit breaker is present in your fridge, it could have tripped if incoming line problems were unstable:
KENMORE TOP MOUNT REFRIGERATOR Parts Model 79573266303 Sears PartsDirect
You can also order needed parts from those pages.
Jun 25, 2015 | Kenmore Refrigerators
My kenmore coldspot mode 106.53394300 is freezing items in the fridge
If further adjustments cannot be made to the thermostat, the next step would be to replace the thermostat or if so equipped, the temperature thermistor.
Jan 30, 2015 | Kenmore Refrigerators
Kenmore sidexside light burned out. replaced bulb, won't light.
There is a plastic switch that works the light in the door jam. Unplugg the fridge before popping this plastic switch out. I would order one first but if your light fixture is in good shape and not burn on the inside and the wires look good it is most likely the door switch. The door switch is just like an on off switch for any light its just spring loaded to turn on when the door opens. good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore fridge/freezer side by side isn't staying cold
Ok so we just had our Kenmore fridge quit cooling , everything in the freezer defrosted , and we lost a lot of food,BUT my husband ordered a part #8201786 which is a starter , and installed it and it worked! The fridge was clicking but it just wouldnt kick on, and the fan still worked. There are websites that you can order the part from, It cost $63.05 with tax!!!! good luck
Mar 15, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator light doesn't work
then tyr and replace the door switch on the refrigerator side. they are relatively inexspensive to buy and are real easy to replace.
Feb 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water or ice from older kenmore side by side
You must pull fridge out the water valve is in the bottom back. Sounds like the valve is stuck open. You can Google your model# to find appliance parts to order new valve.
Nov 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Light Switch Stuck
This is a replaceable part. A new switch can be ordered from Sears by Model number of your refrigerator and name of the part. If you have your owners manual it may contain a list with part numbers. Some of these switches will pop out to be replaced. Others you may have to remove the breaker strip where it is mounted to remove the switch by compressing the snaps on the side of the switch.
May 07, 2008 | Kenmore 60721 Refrigerator
Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
Mar 30, 2008 | Refrigerators
Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Dec 05, 2007 | Refrigerators
Kenmore 57029 Side by Side Refrigerator Logo
751 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
