Question about LG RD-JT91 Multimedia Projector
LAMP goes off after few minutes
I used a LG DLP projector RD-JT91, recently the power supply unit was affected by surge voltage. i have fixed the power but my problem now is that when you power up the system after displaying the welcome sreen the LAMP goes off. Is it that the LAMP need replacement or what exactly is wrong .
  • 682 Answers
1-check the counter reading of lamp to see if it is in the right age of lamp or not.if it is in right age the problem still in power unit or in ballast.
Posted on Mar 14, 2008
I have a Dell 2300MP DLP projector. It lights up for about a minute then the light goes out. Both the Temp and Lamp indicators are glowing after the light goes out. The fan is working. Will just replacing...
Looks like there is power supply problem as well as the lamp.
1 Clean all filters
2 Check out power supply (usually a few capasitors need to be replaced)
3 Wuld be a good idea to check the lamp in wokring projector, but if the "Lamp" light is constantly on it is more likely a faulty lamp as well.
Mar 01, 2011 | Dell 2300MP Multimedia Projector
Tip
Mirror or light tunnel collapsing
A weakness that you might experience with your projector is the collapsing of the light or mirror tunnel. Not sure if this is common to DLP projectors only. The symptom is that you see grey bands or shadows on the edge of the TV image - this is caused by a mirror getting in the way of the bulb light. The glue holding the mirrors together seems to weaken over time (3000 lamp hours in my case) and causes one or more of the mirrors to loose its position. For solution, search for "mirror tunnel" or "light tunnel" under all projectors. The problem seems to be quite widespread. I managed to fix my LG's.
I wonder why the manufacturers don't use a rectangular glass tube that is mirror plated on the long sides ?!?! Suppose they want to sell new projectors after lamp or mirror tunnel expiry!
on Sep 15, 2008 | LG RD-JT91 Multimedia Projector
Dlp projection, keeps switching to standby, also sometimes will start up and the picture goes blank but the sound remains
The lamp may be out. Projectors need high voltage/wattage lamps. They tend to only last 2000 hours or so, which is about a year or two with normal use.
Feb 04, 2010 | LG DLP Projector 1400Lum RD-JT30...
A vertical white strip appears after few minutes.
Hi fabiano did you ever find a solution the vertical line in your RD-JT91 Multimedia OH projector. I now have the same problem. Gary
Oct 02, 2009 | LG RD-JT91 Multimedia Projector
Lamp reset timer
Hi there
There is basically two ways to reset the lamp timer :
1. ) On the Projector's physical buttons
Arrow Keys - Up , Down , Left , Right then Menu and Enter - this should be done quickly whilst the Projector is in standby mode.
2.) Switch Projector on - Hold in the Up Arrow Key on the physical buttons on the Projector untill a PIP screen appears - then just follow the on screen steps.
Sep 25, 2008 | LG RD-JT91 Multimedia Projector
LG RD-JT 21
Hi Mike
Press the following buttons quickly - Up , Down , Left , Right , Menu & then Enter - this should reset the timer.
Sep 16, 2008 | LG RD-JT91 Multimedia Projector
LG RD-JT91 PSU problem
Hi there
On the left hand side where all the inputs are located you will see a very small screw , that is most probably what's keeping you from opening it.
Also remember to take off the cover to the front and do this slowly because the translation board's lint is attached to the top cover. Once open you can just unhook it and then you'll be looking for the board with the AC inlet on it.
Apr 12, 2008 | LG RD-JT91 Multimedia Projector
Reset the bulb
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
Jan 12, 2008 | LG RD-JT91 Multimedia Projector
All lamps are flashing
In PSU, on the secondary side of switch supply there are electrolytic capacitors: for 13 V is 470uF/25V and for 5 (and subsequent 3V) is 1000 uF/16V. Those capacitors in some devices from this series use to break (why? I don't know: maybe cheep quality). Check voltage on rectifiers outputs with oscilloscope: if there are not constant voltage on one of them you should replace it with the new one (of course good quality). I've got the same failure subsequently on 5V supply (this reparation was done by LG service, but when I asked them they answered they replaced mother board - bull shit!) When the same "flashing" problem after guaranty occurred again, I had found soldering traces on the cap on 5V!And guess what - it was cap with a different brand than others.
This solution is maybe only for el-geckos, but no service wanted to repair my quite new, still worth something projector (not in Sweden any way). If you can’t do a job your self you still can ask some handy friend which know how to solder parts. Be careful! There is high, dangerous voltage on primary, so you must know what you are doing!
I'm sometime very irritated: that capacitor cost less in bulk than 2 cents each! But the ordinary people must buy a new projector because of lack of service!
There is PSU diagram:1af7f4a.jpg
Feb 21, 2007 | LG RD-JT91 Multimedia Projector
LG RD-JT91 Multimedia Projector Logo
250 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
Lawrence Oravetz
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
