Question about Lands Phones
Sampling of the signal in "Analog communication".
Q no1) A signal of frequency 4 Kz is sampled at the rateof 3500Hz .What will be the effect on the signal and signal frequency ?
Please show the solution with the help of "MATHEMATICAL CALCULATION" and "RAY DIAGRAM" using sine wave.
Posted on Feb 22, 2008
    Problem Solver:
  • 12 Answers
The signal and signal frequency remain unchanged. In this context, these terms refer to the incoming, and not resultant, aspects of the system.
However, because the Nyquist frequency (1.75kHz, or half the sampling rate) is not greater than the signal bandwidth (4kHz), aliasing will be introduced into any reconstructed signal that is based on these samples. Not enough data about the signal has been captured to be able to recreate it in its original form.
If the signal is very simple (a sine wave, for instance), the "apparent frequency" of the result can be calculated without too much trouble. A more complex signal (i.e. a voice signal with a bandwidth of 4kHz) presents more analysis problems.
I suggest you read your textbook for further information.
Posted on Feb 14, 2008
Pcm 48 khz
mine does the same thing. I found a pdf of the manual and it said this in the troubleshooting section:
""PCM--kHz" appears on the display. , The sampling frequency is more than 48 kHz. Change the DVD setting to 48 kHz."
I have my seiki tv hooked into the dvd/ld input through a coaxial cable, and I don't think my tv has a setting to change the sampling frequency. so I have no idea what to do. any help would be great!
Jan 15, 2014 | Sony STR-DE445 Receiver
What is a common sampling frequency for digital audio?
44.1 KHz is very common, otherwise known as 44,100 Hz, meaning it is sampling the audio 44,100 times per second
Jan 29, 2013 | Audio Players & Recorders
Roland spd 20 analog test error+reason
The adaptor for the SPD-20 is not 12 V ac (Altern Current) the SPD-20 need only Altern current (12V AC)
if the adaptor is 12 v cc, the internal circuits can not made +5v , 0, -5v
for simetrical operactional supply.
And Spd 20 show "Analog test err" and "batery low"
Jan 08, 2012 | Roland Spd-S Sampling Percussion Pad...
Can u hook it to a computer for sound
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
More-advanced sound cards would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
A digital-capable receiver would accept 44.1 kHz for normal CD or DTS sources. Some diddling with the output sampling frequency might allow digital multichannel audio to be decoded by the receiver.
Feb 11, 2011 | Harman Kardon AVR 430 7.1 Channels...
How do I connect my computer to my Sony STR-D915.What if any special cable,adapters,equipment do I need to have all computer sound relayed through the speakers I have ?thanks
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts (*) to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
* http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
YOUR receiver has only analog stereo RCA inputs so you
Feb 11, 2011 | Audio Players & Recorders
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Dec 17, 2010 | Sony Televison & Video
Tracks playing at the wrong pitch and speed
This sounds like a difference in the sampling frequency.  Music recorded at 48Khz must be played back at that frequency or there will be a significant difference in speed and pitch during playback at 44.1Khz. I first noticed this when it occurred to me when recording on digital audio tape.  Ipods and minidiscs and mp3 recorders can record at high sampling frequencies like 48K.  Cds are all recorded at the standard 44.1K sampling frequency.   Check the source of your recordings and it should follow a pattern that leads to your current results.       I do not have enough information  on how your music was transferred to tell you more at this time, but I am very confident that differences in sampling frequencies of your source material are causing the pitch differences you are hearing.   Without knowing exactly the sampling frequencies of each piece of equipment you used to record these songs it will be next to impossible to give you a very specific solution, so I hope the info. I have shared helps you to figure it out.  Best regards and good luck!   Michael Mittelsdorf
Jan 12, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Bouth it used need disc to make it easier to download music with direct connect
Metro PCS just as Sprint PCS does not use the same GSM network as AT&T or Verizon Wireless.
PCS is a completely separate wireless system. The phone MUST be compatible with the PCS communication platform to work properly, in other words it must be able to connect at the proper frequency bandwidth that PCS connects to. GSM uses the 900Mhz frequency range and PCS uses the newer 1.9Ghz.
The 800i does not support the PCS frequency so most likely you will not be able to use it with a prepaid Metro PCS SIM card. There is only T-Mobile prepaid that you can use with the available frequency connections.
As for accessories, there are several places to find adapters, the Sony Ericsson website still carries most components although they a bit more expensive, you are getting genuine Sony hardware. The download software suite can be obtained for free from the Sony website. The software makes transferring files from your PC to phone easier and allows you to change the sampling rate for MP3 files so that you can store more music for your listening pleasure.
I have a similar model Sony phone the W600i and have yet to have a problem with it (2.75 years old). The memory storage is only 256MB, however with reducing the music sampling rate to 64kb from 192kb it allows me to store around 8 hours of music, enough to fly to Europe or South America. The camera has a lot of features found in regular digital cameras like:
White balance
Appeture setting
Date Stamp
Sepia Tone
B/W image
Panoramic Image (Great feature)
Hope this helps you out.
Keith
Oct 16, 2008 | Sony Ericsson W800i Cellular Phone
How do i use the effects processor for more than one track on a roland mv 8800
You can't. Best way is to set your FX on your track. Hit sampling button, then go to the Resampe tab, hit start, run your track, save sample, load it back up. Not exactly how I woulda set things up, So I make everything dry on the mv and dump into my DAW for FX...Not sure what Roland was thinking with this little gem, but hit up MVNation.com...best site for info on the MV. After I found this site, I threw the manual out. Hope it helps.
Aug 23, 2008 | Roland Mv-8000 Sampling/Record Production...
Lands Phones Logo
304 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
