Question about Sony CDX-GT300 CD Player
Memory loss since changing fuse!!!
My fuse for my radio recently blew and i changed it. The power is now back on to the radio but every time the engine is switched off the memory on the radio is lost, the clock resets and all the programmed channels are lost. Any ideas?
  • Adam McDowell Feb 14, 2008
    Thanks for the help. It turned out that i had put the fuse in the wrong position on the fusebox and it was only in one of the holes. I better stick to sports. Thanks again bud.
  • 1,512 Answers
The unit will have 2 fuses, or at least a second power supply that is generally connected to continuous power, best bet is straight from the +ve batt terminal. If this power supply has been disconnected or has a blown fuse, then you will also loose memory functions from you radio.
  1. Check first under the bonnet for a memory backup fuse holder that has generally less than 1 amp fuse,
  2. no luck, then about the rear of your fuse box for a fuse holder,
  3. or worst, behind the unit up under the dash. The wire from the back of the stereo on Sonys is generally the RED one for memory backup
restoring this power supply to your stereo will then allow for all your presets to be retained in memory
Good luck, happy to talk to you more about the problem, a "FixYa" rating will help my profile
regards
Graeme
Posted on Feb 14, 2008
Radio dead after alternator damage
Change the fuse, if it still doesn't work then the circuit can be tested before spending the money on a new radio
May 07, 2014 | 2001 Volkswagen Jetta TDI
Jeep patriot radio stations change on its own
loss of power to radio
or a bad radio.
loose fuse in radio slot?
Mar 21, 2014 | Jeep Patriot Cars & Trucks
Aftermarket stereo won t power on
you blew the fuse
check the fuses to radio, can be 2 or more.
1 in fuse box.
2 in radio, (some have 1 , and others have 2 or 3 more in side radio)
anything is possible with aftermarket, radios, 10,000 models, vast years. Ive repaired many. (ET)
the radio has a red wire, usually for power,
most radios have 3 power wires,
1 for rad ( this one dead) use a volt meter here.12v key on.
1 for dial
2 for memory
Dec 06, 2013 | 1995 Honda Accord
Every time i start the car it resets the clock
The clock and radio memory use a different power source than the radio - - that source is not controlled by the key switch. I would check the fuses first to see if you blew one that is hot all the time.
Jul 15, 2012 | 2007 Mitsubishi Outlander XLS
I lost my horn and speakers on a 2010 road glide anyone know where to look
did you recently change the deck unit stereo somthing in the wireing there or maybe you blew a fuse if you tryed to hook somthing up recently maybe over loaded the fuse and just blew the fuse usually its around the seat or under the gas tank or on the front forks under the lights check the fuse first replace it if it happens again you have somthing over loading it
Feb 25, 2012 | Harley Davidson FXR Super Glide...
The audio/clock fuse blew and every time I replace the 15w fuse it blows
i would try to unplug the clock and the radio change the fuse and see if the fuse blows.
Apr 28, 2009 | Toyota RAV4 Cars & Trucks
Turned car on yesterday, radio would not turn on, bought car used and did not receive an owner's manual.
As to the fuse issue,swap with another fuse of same color/amp rating.Swap fuses one at a time until radio works,usualy a red 15 amp fuse but manufacturers do have a habit of changing things with little or no notice.Unsure wether code would be affected as it should have a constant power source from battery to maintain radios memory.Unless youve disconnected battery fuse should bring it back to life.Good luck and hope not to be too tardy with an answer next time LoL!
Nov 02, 2008 | 2004 Volkswagen Jetta
Blew the fuse
YOU CHECK THE CAR FUSE...BUT THE STEREO HAVE ANOTHER FUSE. CHECK IT IF PROBLEM PERSIST.... I´M SORRY BUT I THINK YOU BLOWIT ,YOU MUST GO TO REPAIRED SOME TIMES BLOW A THIN LINES INSIDE THE STEREO AND REPAIRED THOSE WORK AGAIN AND POWER AMP IN THE STEREO BLOW TOO. GOOD LOCK!!!!
Feb 16, 2007 | Alpine CDA-9855 CD Player
Sony CDX-GT300 CD Player Logo
259 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
