Question about Acer Computers & Internet
Monitor 'drop out'
I just bought a desktop package which includes an Acer AL2223W 22inch monitor-generally it works great except that when using certain programs or trying to view some web pages-especially those with light colored backgrounds-the monitor display flashes to black repeatedly making pages /programs impossible to view. Is it a problem with my monitor or my inbuilt graphics driver? My system is an AcerT690 with Intel Core 2 duo CPU 2.00GHZ-2046MB RAM with inbuilt RadeonX1550 graphics driver
Have tried adjusting monitor refresh rate etc but nothing works.
Ok, the problem with the monitor for programs is actually the Vista Aero. Found out that even though many programs are Vista compatible they do not run with Aero-used program compatibility wizard which reverted Aero to Windows Classic and all is well. Not sure if similar problem is affecting web pages though.
Posted on Feb 15, 2008
I tried to use my acer as a second monitor and it is connected to my GTX 550 Ti graphics card just like my Benq monitor. Whenever I turn on my computer the acer monitor shows the acer logo and then s
Incorporating a second monitor is a great Idea, I've used three to four on my workstations for many years. Setting up multiple monitors involves more than just hardware, the card manufacturer's software and operating system is involved. Since you didn't note the OS, I'll assume Win7. First, simply right click the desktop, and select "Screen Resolution" to see a page headed "Change the appearance of your displays," below which show be a graphic that shows both monitors with a number "1" and "2" on each. Arrange them by dragging and dropping them to reflect your physical arrangement. Then, select the fourth drop-down titled "Multiple" Displays" and select "Extend desktop onto this display," then click the "Apply" button followed by the "OK." button. If your hardware and drivers are set up properly, you should have everything working at this point. Your Nvidia software should have installed a control panel item that you can use to make tweaks to your system. You can also contact Nvidia technical support for more detailed, OS-specific assistance.
Jan 17, 2015 | Acer 23" LCD Widescreen Monitor S230HL BD
Power supply
try ebay
acerspareparts.com
superwarehouse.com
Dec 05, 2012 | Acer AL2223W 22" LCD Monitor
How do i remove the back cover of my al2223W monitor?
Remove all the screws and the stand, then use thin flat blade screw driver to separate them starting at the bottom edge and work your way around, be careful on the cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL2223W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 10, 2011 | Acer AL2223W 22" LCD Monitor
Acer monitor model # AL2223W screen goes black
need some clarifications on here. you connected the Acer Monitor to your Dell laptop right? when you opened the screen goes black. i believe you have to press the FN + F7 or FN + F5 on your laptop to make a display on the Acer Monitor.
Apr 14, 2010 | Computers & Internet
Screen comes on says Acer then No Signal, and goes out. if shut power off and then back on get same result.
This means the monitor believes it's not connected to the computer. Verify the cables first of all. Then try booting in safe mode (F8 key at PC startup) in order to verify that the PC is sending data to the proper video port (you might have a dual VGA / Digital output, for example, and the monitor might be connected to the wrong PC port). Quite often, a "bad signal" will be the same of "no signal"; and you can have a bad signal if the monitor resolution on the PC is set too high. This could happen if you installed a high-resolution capable monitor, and then replaced it with a not-completely-plug-and-play, lower resolution one. The PC would keep sending hi-res signals to a monitor which can neither interpret them, nor tell the PC "please slow down". To check this last possibility, reboot your computer while the monitor is ON. When PCs reboot, they usually drop back to standard VGA signaling, which all monitors understand. If the monitor abruptly comes to life and displays a boot screen, then goes No Signal again after several seconds, you've got a resolution issue; get in Safe Mode with F8 key at boot, and modify the screen properties (right-mouse button on the desktop, then Properties).
If everything else fails, try also connecting the monitor to another PC or laptop, to see if it works there.
Dec 04, 2009 | Acer AL2223W 22" LCD Monitor
My Acer 22" AL2223W monitor display goes black after a few seconds, How can i fix it my self?
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
Sep 01, 2009 | Computers & Internet
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Apr 05, 2009 | Acer AL2223W 22" LCD Monitor
I have baught a new 22inch acer p223w monitor for my xbox 360. how do i get sound out of the monitor?
There are no speakers built into this monitor. You will have to purchase speakers in order to get sound.
Dec 18, 2008 | Acer Computers & Internet
Monitor going to stand bye as soon as turned on
  1. Make sure your monitor is properly connected to your CPU VGA ie the screw are tight and the cable is not damaged
  2. reduce down the setting of your screen resolution to those specified for your LCD or just low settings like 600*800
  3. To do that you use your old monitor and on the desktop right click and select properties and under the settings tab select to reduce the settings to native settings or any low screen resolution
  4. Restart your PC with your LCD connected back
Mar 24, 2008 | Acer Monitor
DVI cable not working
If you still have your old monitor plug it back in for a bit and load the drivers for the new monitor (from the disk which came with the new monitor). Right click on your desktop and choose properties and set your display resolution to something like 1024 x 768. Shut down the pc and connect your new monitor to it with the dvi adapter. If it is recognised ok you can then set the resolution from 1024 x 768 to the recommended amount for your new screen. The refresh rate is also important as some lcd screens only work at a certain level. There should be an auto switch on the monitor and if you press this it sets the display to optimum, - or should do.
Mar 21, 2008 | Computers & Internet
Computers & Internet Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
