Question about Philips DVP3050V/37
VCR wont record
DVD player and tuner on VCR work fine. Initial problem was that VCR would record for about 4 mins and then stop recording. Now it will not play tapes as well. I have cleaned the heads to no avail.
  • 979 Answers
Youmay very well have a capstan drive problem that could be resolved by either replacing or even just cleaning the friction surfaces...accordianman
Posted on Feb 15, 2008
How do i record from a vcr tape to a dvd on a sansui dual deck vcr dvd recorder?
If it is a combination VCR/DVD player,they usually can't do it.If you get a separate VCR player from a friend or neighbor,you can connect the VCR output to a cable box input,cable box output into DVD input,or if the DVD recorder has a digital tuner you can plug the VCR output player straight into the input of the DVD recorder.DVD recorders REQUIRE some form of digital input.That is why you need to route a VCR player through a cable box or the DVD recorder needs a digital tuner.If you are not sure if your recorder has a digital tuner,call sansui,they will know.I tried to find Sansui home and I found everything BUT DVD/VCR.If you have a manual it will be in there,or it may have a phone number on a label(back or bottom probably)of the unit.Good luck!Greg If you want to send me your model number,I will research it further too.It is up to you.
Aug 06, 2010 | Televison & Video
My recorder wont record on new discs
Daewoo DVD Recorder/VCR combi (I believe the model number is DF-4100P it wont record on disc but it will on tape mode plus the drawer in the dvd wont open please can someone send me an answer of whats wrong with it thank you
Apr 05, 2010 | Daewoo DVRS05 DVD Recorder/VCR
Panasonic DMR-ES40V VCR won't schedule record: Recently, the VCR will not do scheduled recording anything beyond today. I can schedule a recording and it appears OK (I get red light on panel), but I never...
I found this solution on one of your old notes (but a different machine). I set up a scheduled record for 11:59 PM to 12:01 AM for the current day, then set up the scheduled record for the next day. The VCR recorded both the initial 2 minute session and the later one which I wanted to record.
Dec 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Sony VHS model no: SLV-SE710G isn't recording now that we have a freeview box. It just keeps changing back to L1 whenever i try to record anything!! I only want to record channels 1,2,3,4 !! HELP!!
Its hard to work out without looking at your cables. I assume the problem started when the freeview box got set up. I would guess that the aerial cable is now in the set top box instead of the vcr as the vcr sounds like it is unable to record when there's no signal (a common feature) so there shouldn't be a fault with the vcr,
just unplug the aerial from the set top box & plug it back into the vcr. Ch 1 2 3 4 should be back on vcr but set top box wont have any Ch.
most set top boxes have an aerial output, so you'll need another aerial cable, plug this into the aerial input on the vcr & ch 1 2 3 4 will be there but these will be analog (if your area has stopped analog transmission thats the prob rite there)
If you plug the matching cables from the set top box into L1 on vcr you'll be able to record digital tv as L1 use a signal from another tuner eg set top box, dvd player whereas the vcr channels 1 2 3 4 use the vcr's built in analog tuner. so it shouldn't be a biggie another cable should fix it,
Hope this is helpful, ask if you need more info
Aug 20, 2009 | Sony Televison & Video
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Can't recorder digital broadcast
Hi,if your vcr is an analog machine then you will not get a signal.If you have a seperate digital box then you can connect this via a scart lead to av2 on the vcr.Best thing though is to buy a digital dvd recorder.hope this is of some help.jamie
Mar 02, 2009 | Zenith XBV443 DVD Player/VCR
Channel selection
L1 and L2 are just line inputs. This unit does not have a tuner so there are no channels to select.
It requires you to be connected to a TV broadcast via a cable or satellite tuner box... and then would only record what ever channel you were viewing. The DVD is a player only.
It sounds like you should have purchased a DVD Recorder or a DVD/VCR Recorder. The players normally do not have a tuner. A Recorder should have an built-in digital tuner. Some also have the old NTSC tuner and may also have a QAM tuner.
Nov 12, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording TV shows
Since it doesn't have a tuner, it will not be able to store channels - it will only record the channel that your cable or sat box is on currently
Aug 19, 2008 | Philips Magnavox DVD/VCR Dual Player
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Mar 19, 2008 | Sanyo VHR-5431 VHS VCR
VR2945 DVD recorder VCR combo
Use it as a boat anchor!!!
I've tried and tried and gave up.
Jan 17, 2008 | GoVideo Go Video DVD/VCR Combo
Philips DVP3050V/37 Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
