Question about Brother MFC 210C All-In-One InkJet Printer
Printing photos hi, i cant get my Brother MFC-210C to print photos i have changed all the setting i am using glossy paper but it keeps jaming it seems like the papers to thick any ideas on what i can do, i have printed photos on to photo paper from this printer in the past.
  • Sheridan522 Feb 19, 2008
    I can't print labels either, same problem, but the two boxes of labels I have don't specify the weight/thickness of the paper. What can I do!??
  • 832 Answers
The restriction of paper weight is 220g (see www.brother.com too)
You are better up by useing photo paper no thicker than 200g
Posted on Feb 14, 2008
My Brother MFC 210C Printer, Copier, Scanner isn't feeding the paper.How do I fix this?
Use a water dampened cloth to clean the pickup roller. They get residue on them over time that causes them to not grip the surface of the paper when feeding.
Feb 06, 2015 | Brother Office Equipment & Supplies
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Mar 23, 2009 | Brother MFC-5890cn Color Flatbed...
Glossy paper jams
hello! most printers will only print on regular , you can not use glossy paper. the paper pick up rollers will not grab the paper, they tend to skid on the paper, good luck. brother tech
Jan 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Lousy print quality
That might be a problem of the photo paper. Use another brand and have a look at the manual to set the right paper settings.
Feb 20, 2008 | Brother MFC 210C All-In-One InkJet Printer
Photo paper jamming.
You didnt tell us what phtopaper you use. Especially the weight of the paper! Brother printers are known to have probs with paper thicker then 220g. The paperfeeder cant feed the paper correctly into print position.
another reason might be that the paper isnt placed well into position. Have a look around the FAQ, too:
http://welcome.solutions.brother.com/bsc/public/as/nz/en/faq/faq_top.htm?reg=as&c=nz&lang=en&prod=mfc440cn_all
BTW: If you print a lot of photos it might be cheaper to do that with a (online) print shop.
Jan 04, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-210 Printer Trouble
unplug for at least 20 minutes, then disconnect all the cables from the printer, plug power cable back in and turn back on
what happens?
look in your manual, is there anything to set back to factory default? if so do this if the first steps don't work
Jan 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
RE PRINTING OUT AN IMAGE FROM MY BROTHER MFC-215c PRINTER
Neither nor do I press any of these buttons because you can print by help of the photo assistant of windows which will give you a hand.
Simply right click the picture on your pc and click printing. The assistenat will lead you thru the settings. You only have to make sure that your mfc is the chosen as the printer AND you havte to click the printer properties afterwards. The brother printer properties will let you choose the paper size (simply click the offered sizes and have a look at the left side of the window where a small pic can be seen. Beneath the pic you will find the explanation for the choosen setting e. g. borderless/ 4x6 inch etc.) choose the right paper like glossy for photo paper. When done click OK and leave the properties. Click further through the windows assistant and choose the resolution of the picture. Click OK and machine will print the desired pic ;-)
BTW you can do some very smart thing:
print a poster of 2x2 A4 or 3x3 A4 sheets of paper. You can set this size within the printers properties.
Have a look at the manual for further info ;-)
Dec 06, 2007 | Brother MFC 210C All-In-One InkJet Printer
Black ink won't print,just the color ink prints. It's a Brother MFC-3240C thanks in advance
You must run a clean cycle after installing a new cartridge.
Try running a clean cycle and see if that relieves the problem. I just had the same problem on a MFC 210C and called Brother. That is what they had me do and now it is working fine.
Oct 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
224 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
