Question about Konica Minolta Di1610 Copier
Konica Minolta Di1610 can't print
Computer can't detect the printer even after installing the driver. Printing test not working.
  • 19 Answers
This printer can only be connected via usb to a local computer, unless it has a network card called the N C-5.
Posted on Apr 15, 2008
The Di1610 is not a network printer (no ping).
Posted on Mar 10, 2008
  • 3 Answers
Hello
is it conect via net or parall port?
have you try to detect the printer by its ip ?
(ping)
pini
Posted on Feb 14, 2008
My bizhub is printing gibberish when i connect my laptop via office network.
Well if the other computers print ok to the Bizhub its not the machine, copier does not pick and chose which computer will not work. Try this web site for the most up to date print driver
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 11, 2014 | Konica Minolta Minolta Bizhub C353 Copier
I have Konica Minolta bizhub 350. My computer is already detected bizhub 350 but not print Thanks
When your computer has detected the photocopier machine, then the next step is to install the drivers, which you may find in CD-ROM or you can Google it.Drivers are easily available on the internet.Download the drivers, Install the printer and then execute print command.It will surely work. If you want to use it as a single pc printer then its ok, if you want to use it over network, as a network printer, then you have to assign IP address to machine.
Mar 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta 1350 printer won't print with Vista
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
Sep 15, 2009 | Konica Minolta PagePro 1350W Laser Printer
Biz hub 250 Pdf printing problem
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
HH
Aug 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Magicolor 2450 printer will not recognize printer
did you reload the print drivers
Mar 22, 2017 | Konica Minolta Magicolor 2450 Printer
IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Feb 25, 2009 | Konica Minolta Di1610 Copier
Konica Minolta Bizhub 920
You need to set machine for extra cassette.
Nov 23, 2008 | Konica Minolta Di1610 Copier
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
Scanning documents
You have to install driver with software, you can get it from www.konicaminolta.eu
Also you can scan with MS office or other Windows software, if you installed Twain scanner driver.
Find driver and software link below:
http://download2.konicaminoltaeurope.com/openmind/technic/kmbsdwl.nsf/psearch?openform&ch=MFP&dist=BEU&ui=en&dg=sw&prod=Di1610&dsg=&os=&lang=&ml=0&rid=&sub=&pcat=&pcc=
Nov 14, 2007 | Konica Minolta Di1610 Copier
Konica Minolta Di1610 Copier Logo
339 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
