Question about EliteGroup P965T-A Motherboard
RAM Problem Dear Sir, Can I use a 1 Gb DDR2 533 Kingston and a 1 Gb DDR2 667 Corsair simultaneously on a P965T-A Motherboard. Hoping for your answer. Best Regards, Toti
Yes it does work, but the Corsair will down clock to 533.
Posted on Mar 04, 2008
I ALSO HOPE THAT BOTH RAM WOKS SIMULTANIOUSLY
BCZ BOTH ARE SAME MODEL BUT SPEED ARE DIFFIRENT
Posted on Feb 14, 2008
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Asus m2nmx does not support additional ram in win 7
That motherboard supports up to 4 GB. Make sure that the sticks are exactly the same and are put in the first socket of each channel.
Mar 19, 2010 | ASUS M2N-MX Motherboard
I have installed 1 GB + 512 MB DDR II RAM, but it read only 1G I have just bought the Corsair 1GB RAM (DDR II 667 MHz, 6400), and installed it in the slot 1 of my motherboard, but it only read as 512 MB. (...
Nowadays, motherboards supports only a selected number of RAMs. You have to read the manual and select from the given models. I am not talking about DDR2 or 667MHz. The manual will state the manufacturer (ex. Kingston) model no (KVR667XXXXXX) etc. Only those stated in the manual will work correctly with your motherboard.
Aug 14, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Can i use 2 diff brands of RAM simultaneusly 1gb corsair ddr2 667 and 1gb transcend ddr2 800 for P965T-A
It is better to use the same brand.
These to brands might work together, you don't know until you put them in your computer and test it.
May 15, 2009 | EliteGroup Computers & Internet
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Additional ram
yes there might be a problem you will encounter, first, if you purchase with wrong specifications, 2nd you should be ready with the erros that will appear like the memory dumping and so on, 3rd are you familiar with the location. if you will purchase you should remove and present your existing ram so that this will be their reference with the specifications
Nov 25, 2007 | EliteGroup P965T-A Motherboard
Motherboard and ram..
DG965WH Board works well with 533 RAM, but is very finicky about 800, if you use 800, use only what is recomended.
I used kingston KVR533D2N4K2/2G with good luck on 4 motherboards.
You can try it, but watch for crashes and stabilty issues, if it has issues, remove it.
Nov 20, 2007 | Intel DG965WH Motherboard
EliteGroup P965T-A Motherboard Logo
78 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
