Question about Canon PowerShot A70 Digital Camera
Canon powershot A70 digital camera
My camera displayed memory card error, was advised to format the memory card which i successfully did but it didnt solve the problem although this time it doesnot display it instantly on switching it on like before but rather displays a blank screen and after some time displays the error message
  • katungu hillary Mar 05, 2008
    thanks for the advice will try it out and hope you'll accept ma request.
  • Canon Master
  • 4,738 Answers
The memory card may be failing. Recommend trying a different memory card to verify. Do you still have the original low value card that came with the camera? If so, try that one to see if you still have the problem. If that one checks fine, then you know it's time for a new card.
Posted on Feb 16, 2008
No Memory Card error
Check to see the largest capacity card that the camera will accept - if you are trying to use cards larger than this, I would expect this error.
Jul 28, 2017 | Canon PowerShot A70 Digital Camera
Canon Powershot A70. I get a 'Memory Card Error' when I turn it on. Did this three different cards. They don no appear to be defective. I just transferred all of the pictures form them to another hard...
When you transferred the pics from the cards to your computer, did you use the "safely remove hardware" function before removing the cards or cord or whatever method you used? If not, this is why you're getting the error message. If the pics are safely downloaded, format the cards in the camera to get them working again.
Sep 03, 2010 | Canon PowerShot A70 Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Memory card,CANON powershoot A70
You shoould be able to do it with the camera options. If not you can do it withthe camera.
Here's the instructions.
http://www.ehow.com/how_2112408_format-memory-card.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
May 17, 2009 | Canon PowerShot A70 Digital Camera
I keep getting an memory card error message on my canon PowerShot
try doing a format with the camera. there should be an icon of a wrench in the menu--in this sub menu you will see "format." this action will erase anything on the card. i actually had the same problem with a canon camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
Mar 18, 2009 | Canon PowerShot A550 Digital Camera
Memory card error
do one thing. as per canons manual:
if any error is displayed when using your memory card do a low level formating of memory card.
but what to do for pictures in it? get a memory card reader from market. its very cheap. its also advisable to use memory card reader to transfer your photos rather than using direct connectiin to computer.
after doing a low level formating then transfer photos inside memory card from system, put it in ur camera, then enjoy.
hope you are clear with your problem. please give a feedback.
Dec 03, 2007 | Canon PowerShot A520 Digital Camera
Memeory card error
many users have the same doubt. as per canons manual:
but what to do for pictures in it? get a memory card reader from market. its very cheap. its also advisable to use memory card reader to transfer your photos rather than using direct connectiin to computer. bcz any lekage current from computer may damage the camera in some way.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Formating a CF sandisk card
I dont know about formmating CF sandisk card with canon A70, however, i can recommend another method: hook it up to your desktop and format it through a CF adaptor. It may take a couple of attempts. it didnt do any damage, at least not one that im aware of. Im not 100% sure though, so don't get me responsible in case it will damage yours. anyways, if you do it, you can try the process described above. good luck.
Apr 03, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
