Question about Philips Magnavox Learning Universal Remote
Help I have a philips magnavox remote universal the rem 250 cfmp0018 cav#3 qc1234pass5678 and i looked up codes online because i lost code sheet to program my panasonic but the remote does not seem to respong and i changed the batteries?? So what should I do
  • 1 more comment
  • tuke77m May 12, 2008
    I have the philips universal remote and I lost the code book. My T.V. Is a Sylvania. Do you have the code for this? thanks
  • Anonymous May 15, 2008
    my codes won't work on my Sanyo TV, can you help
  • Anonymous Mar 13, 2014
    I need the codes for my tv. its philips universal remote CFMP0018 CAV#3
I have a philips universal control and I need the code for a memorex tv
Posted on May 16, 2008
Need instructions to set code for tv
  • 1 Download or view the user's manual from the Magnavox website (see Resources). You will need the list of codes included in the manual. The website will direct you to the closest remote control manual available similar to the REM 350 Universal Remote. This manual is compatible with the REM 350 Universal Remote.
  • 2
    Press and hold the "Code Search" button until the red indicator light stays on. Release the "Code Search" button.
  • 3
    Press and release the "Mode" button for the product you wish to program (TV, VCR, DVD or satellite). The red indicator light will blink, then stay lit.
  • 4
    Enter the four-digit code from the code tables listed in the user's manual. You can also search for the code online at the Philips Universal Code Finder page (see Resources). You might have to try several or all codes listed in the manual until you find the correct one. After a valid code entry, the red indicator will turn off. With an invalid code, the red indicator flashes.
  • 5
    Press the "Channel Up" button with your device on (TV, DVD, VCR, or satellite). If the device responds, you have completed the programming. Once are certain you have found the valid code, make a note of it somewhere so you will not have to search for the code again.
  • Jan 14, 2011 | Philips Magnavox REM-350 Remote Control
    How do you program a philips universal remote
    NEED INSTRUCTIONS FRO PHILLIPS MAGNAVOX CFMP0018 CAV#4 REMOTE
    Jan 23, 2010 | Philips Universal PH301S Remote Control
    Cant find codes for rem 110
    I have the same remote. I googled "philips magnavox universal remote rem110" and found the manual here: http://www.rockabilly.net/files/manuals/REM110.pdf
    Sep 29, 2009 | Philips Magnavox Learning Universal Remote
    Philips magnavox cfmp0018
    Here is the link for the Philips website.
    http://www.support.philips.com/support/html/index_us_en.html
    They can help identify the correct numbers that are required to determine your specific remote. From there it should be simple to download the instructions with the codes that you need.
    I hope this helps, good luck!
    Kym McC
    Oct 09, 2008 | Philips Magnavox Learning Universal Remote
    Need codes for a philips universal remote code sheet
    http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
    This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
    Programming with Code Search
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
    3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
    4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
    Hope this helps :)
    Jun 21, 2008 | Philips Magnavox Learning Universal Remote
    Tv codes
    Hello, Well I have a Phillips universal remote but but maybe they are the same. For the Orion TV try 105, 115, or 713. For The Pioneer DVD Try 042. If one or more does not work, Look for a "code Search" button. Turn on the device, then push and hold down the code search button until the red indicator stays on, then release the search button. Press and quickly release the desired mode button (TV, DVD, etc). The red indicator blinks off once. . If it is a tv or vcr use the channel up button until the channel changes. Press the power button on DVD and see if it is right Hope this helps.
    Mar 16, 2008 | Philips Magnavox REM-350 Remote Control
    Philips universal remote control cl034
    hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
    Mar 08, 2008 | Philips Magnavox Learning Universal Remote
    Philips Magnavox Learning Universal Remote Logo
    352 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
